How to Get Paint to Stick to Plastic
Painting plastic surfaces can be a daunting task, often resulting in poor adhesion if not done correctly. Whether you're looking to rejuvenate outdoor furniture, automotive parts, or household items, keeping paint from peeling off plastic starts with proper preparation and the right products. KBS Coatings offers indispensable products to get paint to stick to plastic: KBS Klean, Fusion SEP Self-Etching Primer, and Fusion FPP Flexible Plastics Primer.
Understanding the Challenges of Painting Plastic
Plastic surfaces present unique challenges for paint as they are smooth and non-porous. Traditional paints often struggle to adhere effectively, leading to peeling and flaking. To make paint adhere to plastic, specialized plastic primers are used to create a strong bond between the plastic and the paint, leading to better adhesion and a more durable finish.
What is Plastic Primer?
Plastic primers are typically formulated with special bonding agents that help the paint grip the plastic surface and keep paint from peeling off plastic. These primers may also have flexible properties, which is important since plastics can expand and contract with temperature changes, especially soft plastics that flex.
For soft plastics KBS Coatings offers Fusion FPP Flexible Plastics Primer. For hard plastics, Fusion SEP Self-Etching Primer is recommended.
What's the Best Primer for Soft Plastics?
Getting paint to stick to soft and flexible plastics, such as rubberized plastics, vinyl, or soft PVC, requires a flexible plastic primer. Also known as elastomeric primer or adhesion promoter, flexible plastic primer incorporates a flexing agent that allows the primer to strongly bond to soft plastics and provide a strong yet flexible base coat that will move with the plastic, avoiding delamination, cracking, and peeling.
Warning: Don't Use a Rigid Primer on Soft Plastic
A primer not intended for soft plastic won't work well or may not work at all. A self-etching primer designed for metal or hard plastic cannot flex with soft plastic to remain adhered, potentially causing the primer and top coat to crack and peel.
KBS Fusion FPP - Flexible Plastics Primer
KBS Fusion FPP - Flexible Plastics Primer - Flexible Surface Primer - Aerosol Can
KBS Coatings offers KBS Fusion FPP - Flexible Plastics Primer for promoting a tight bond between flexible plastics and most varieties of top coats. It can also be used on other surfaces including urethanes, wood, fiberglass, and carbon fiber.
Fusion FPP is a user-friendly plastic primer spray paint that's easy to apply after preparing the surface. The gray colored primer has a fast dry time that allows film thickness to be built quickly.
What's the Best Primer for Hard Plastics?
Hard plastic primers are made for rigid materials that don't bend or flex. These primers are formulated to form a strong, durable bond with smooth, non-porous surfaces such as polycarbonate, acrylic, or ABS plastic. They tend to be more rigid once dried, as hard plastics don't need the same level of flexibility as soft plastics.
Primers designed for soft plastic can typically be used on hard plastics, but they may not be the ideal choice. Flexible primers are designed to handle movement and stress, so they may not provide the same hard, durable finish as a dedicated hard plastic primer.
KBS Fusion SEP - Self-Etching Primer
Fusion SEP - Self-Etching Primer - Inter-Coat Primer - Bare Metal Primer
KBS Coatings Fusion SEP Self-Etching Primer is an adhesion-promoting primer not only for hard plastics but also for metals such as steel, brass, and aluminum. On metal surfaces its self-etching ability etches an anchor pattern for best adhesion. It also performs excellently as an inter-coat for adhesion between multiple surface coatings.
How To Paint Plastic
Fusion SEP is user-friendly, easy to apply, and fast drying. After preparing the surface, it can be sprayed or brushed on. The primer is available in aerosol form as well as in pints, quarts, and gallons.
Step-by-Step Guide to Get Paint to Stick to Plastic
Before applying primer, thorough surface preparation is essential.
Step 1: Cleaning
For primer adhesion that will stop paint from peeling on plastic, any dirt, grease, wax, or other contaminants must be completely removed. KBS Klean is designed for this purpose: a strong, concentrated cleaner that doesn't leave residue that can interfere with primer adhesion.
KBS Klean is mixed with warm water and applied with a sponge, bristle brush, or scouring pad. The tool used depends on how stubborn the contaminants are. After contaminants are removed, the surface is thoroughly rinsed with water and completely dried with a clean, lint-free cloth or compressed air.
KBS Klean - Powerful Concentrate Water Based Cleaner and Degreaser
KBS Klean Directions
Detailed use and safety instructions for KBS Klean can be found here: kbs-coatings.com/kbs-klean-directions
Step 2: Scuff the Surface
Scuffing or lightly sanding the plastic can help primer adhesion by providing a slightly rough texture the primer can grab onto. This is typically more of a preparation procedure for hard plastics. Flexible primers used on soft plastics often don't require sanding, as they are designed to bond to plastic without roughening the surface. However, for maximum adhesion, soft plastics can be scuffed.
Pro Tip: Use Fine Sandpaper and Light Pressure
Plastic can scratch and gouge easily, which can show through to the final finish. Use fine sandpaper (400-600 grit) or steel wool with light pressure in a back-and-forth motion. Adequate scuffing is indicated when the surface sheen has slightly dulled.
After scuffing, plastic dust residue must be completely removed to avoid primer adhesion issues. This can be done with hot water and a sponge; use of KBS Klean as described above will produce the most thorough results. The surface must be completely dried with a clean, lint-free cloth or compressed air before priming.
Step 3: Primer Application
Safety
Always work in a well-ventilated area and wear appropriate respiratory and eye protection when handling primers and paints.
Temperature and Humidity
Ideal application conditions are between 55-82°F with humidity below 85%. Avoid painting in direct sunlight or excessively humid conditions.
Mixing
Before applying primer be sure it is mixed thoroughly. If stirring, use a paint paddle and mix from top to bottom for at least one minute. If using an aerosol, shake the can for at least one minute once the mixing ball moves freely, then shake for 10 seconds after every minute of use.
Fusion SEP Self-Etching Primer Application
  • Fusion SEP can be applied by brush, roller, spray gun, or in aerosol form. Spray gun or aerosol are preferred for the smoothest and quickest application. When spraying, hold the nozzle 10-14" from the prepared surface and apply in steady, even, overlapping strokes.
  • Apply a light and even coat. A single coat is generally all that is required, but 2 to 3 light coats can be added when needed, allowing a 3-5 minute dry time between each coat. Keep coats light to avoid runs and ensure proper curing.
  • Fusion SEP will be dry-to-the-touch in 15 minutes. Allow a one-hour dry time before sanding, priming, or top-coating. Always coat over within 7 days. If after 7 days, scuff with 300 grit sandpaper. There is no need to sand if coated over within 24 hours.
Fusion SEP Directions
Detailed use and safety instructions for Fusion SEP can be found here: kbs-coatings.com/fusion-sep-directions
Fusion FPP - Flexible Plastics Primer Application
  • Fusion FPP is applied in aerosol form. Hold the nozzle 10-14" from the prepared surface and apply in steady, even, overlapping strokes.
  • Apply a light and even coat. A single coat is generally all that is required, but 2 to 3 light coats can be added to fill small imperfections, allowing a 3-5 minute dry time between each coat. Keep coats light to avoid runs and ensure proper curing.
Fusion FPP Directions
Detailed use and safety instructions for Fusion FPP can be found here: kbs-coatings.com/fusion-fpp-directions
Top Coating Plastic Primers
Both Fusion SEP and Fusion FPP can be top coated with a variety of paints and coatings including KBS BlackTop, KBS MAXX, KBS Top Coater, and KBS Top Coater Aerosol.
Many plastics do not hold up well to UV light, which causes them to chalk and fade. Solid color top coats applied over properly primed plastic provide strong UV protection and significantly extend the life of the surface.
  • Allow 1 hour for Fusion SEP or 30 minutes for Fusion FPP to dry before applying another topcoat or primer.
  • Always coat over Fusion SEP or Fusion FPP within 7 days. If you want to apply after 7 days, scuff the primed surface with 300 grit sandpaper first.
  • For exceptionally smooth finishes, lightly sand the primed surface with fine-grit sandpaper (600-800 grit) after it has cured.
Conclusion
The best way to get paint to stick to plastic is using proper preparation techniques and the right products. KBS Klean, Fusion SEP Self-Etching Primer, and Fusion FPP Flexible Plastics Primer offer reliable solutions to ensure your painted plastic projects are durable, attractive, and resistant to peeling or cracking over time.
What makes plastic surfaces difficult to paint?
Plastic surfaces are smooth and non-porous, making it difficult for traditional paints to grip. Without proper preparation and a plastic-specific primer, paint often peels and flakes off.
What is the best primer for soft or flexible plastics?
KBS Fusion FPP Flexible Plastics Primer is formulated specifically for soft and flexible plastics like rubberized plastic, vinyl, and soft PVC. It incorporates a flexing agent that bonds strongly to soft plastics while moving with them to prevent cracking and peeling.
What is the best primer for hard plastics?
KBS Fusion SEP Self-Etching Primer is recommended for hard plastics. It forms a strong, durable bond with rigid materials like polycarbonate, acrylic, and ABS plastic, and also works on metals such as steel, brass, and aluminum.
Do I need to sand plastic before priming?
Lightly scuffing hard plastic with 400-600 grit sandpaper improves adhesion by creating texture for the primer to grip. For soft plastics, scuffing is optional since flexible primers bond without roughening, but it can maximize adhesion. Always remove sanding dust before priming.
How long does Fusion SEP take to dry before top coating?
Fusion SEP is dry-to-the-touch in 15 minutes. Allow 1 hour before sanding, priming, or applying a top coat. Always top coat within 7 days; if more time has passed, scuff with 300 grit sandpaper before coating.
Can Fusion SEP or Fusion FPP be used on surfaces other than plastic?
Yes. Fusion SEP also bonds to metals such as steel, brass, and aluminum, and works as an inter-coat adhesion promoter between multiple coatings. Fusion FPP can also be applied to urethanes, wood, fiberglass, and carbon fiber.
What top coats are compatible with Fusion SEP and Fusion FPP?
Both Fusion SEP and Fusion FPP are compatible with KBS BlackTop, KBS MAXX, KBS Top Coater, and KBS Top Coater Aerosol.
What temperature and humidity conditions are best for applying plastic primer?
Apply primer when temperatures are between 55-82°F and humidity is below 85%. Avoid painting in direct sunlight or in excessively humid conditions.
Ready to Start Your Plastic Painting Project?
Shop the products used in this guide directly from KBS Coatings.
Shop KBS Klean Shop Fusion FPP Shop Fusion SEP Contact Us
