DiamondFinish Clear 1K Aerosol on Custom Fishing Baits
⭐ Customer Review — Speedbaits, Jacksonville, FL
"KBS Coatings sets the standard on durable finishes. I use DiamondFinish Clear 1K Aerosol to protect the paint on my custom baits and it wears like iron. If you want a product made to stand up in a tough marine environment, this is it. Tough as nails, great gloss and made in the USA!"
DiamondFinish Clear 1K Aerosol is a tough clear coat that applies direct to ferrous metals and aluminum, or over other coatings. It uses a professional-grade acrylic resin system for supreme clarity and adhesion, and does not yellow, crack, or peel.
💡 Pro Tip — Marine & Custom Finish Applications
DiamondFinish Clear 1K Aerosol is a favorite for protecting custom fishing lures, painted boat hardware, and decorative metal parts exposed to water and UV. Apply light, even coats and allow proper cure time for maximum gloss and durability.
What can DiamondFinish Clear 1K Aerosol be applied to?
DiamondFinish Clear 1K Aerosol can be applied direct to ferrous metals and aluminum, or over other coatings. It bonds to a wide range of surfaces and is well suited for marine environments, custom paint, and decorative finishes.
Will it yellow, crack, or peel?
No. DiamondFinish Clear 1K Aerosol does not yellow, crack, or peel. Its professional-grade acrylic resin system is formulated for long-term clarity and adhesion.
Is it good for marine use?
Yes. DiamondFinish Clear 1K Aerosol is built to hold up in tough marine environments. It resists moisture, UV, and most solvents and oils, making it a reliable choice for boat hardware, custom fishing lures, and other marine applications.
Can it be applied over other coatings?
Yes. DiamondFinish Clear 1K Aerosol can be applied over other coatings in addition to direct-to-metal application on ferrous metals and aluminum.
Is DiamondFinish Clear 1K Aerosol made in the USA?
Yes. DiamondFinish Clear 1K Aerosol is made in the USA by KBS Coatings.
Ready to order or have questions?
Shop DiamondFinish Clear 1K Aerosol directly on our site or reach out to our team, we're happy to help you find the right product for your project.
Shop DiamondFinish Clear 1K Aerosol DiamondFinish Clear (Liquid) Contact Us
