Ford Corporate Blue Motor Coater On Oil Pan
Real results from real customers. See how Roger C. transformed his oil pan using a full KBS Coatings system, from rust protection to a show-quality color finish with added clear coat protection.
Customer Review — Roger C.
"After modifying my oil pan, I stripped it, coated it with RustSeal, wet sanded, and finally painted with Motor Coater Ford Corporate Blue. I sprayed the sides of the sump with DiamondFinish Clear after adding the Ford rub-on decals for extra protection. It turned out beautiful."
Oil pan restored and painted in Ford Corporate Blue using KBS Motor Coater and DiamondFinish Clear
Products Used in This Project
✓  RustSeal — rust preventive coating applied directly to bare metal
✓  Motor Coater — engine enamel in Ford Corporate Blue
✓  DiamondFinish Clear — top coat for added gloss and protection
Motor Coater is easy to apply, offers superb coverage, and yields a self-leveling professional finish whether brushed or sprayed. These engine enamels feature deep, rich pigmented colors for excellent hide and a lasting factory appearance.
DiamondFinish Clear is a crazy tough clear coat that can be applied direct to metal or over other coatings. It is a water-clear, high-gloss topcoat that remains permanently flexible and performs in the toughest environments without yellowing, cracking, or peeling, making it ideal for sealing decals and detail work like Roger's Ford badges.
Ready to Start Your Project?
Shop the products Roger used and get everything you need for a professional engine or component finish.
Shop RustSeal Shop Motor Coater Shop DiamondFinish Clear
