How to Prepare Metal for Painting Using KBS Klean and RustBlast for Superior Adhesion
How to Prepare Metal for Painting: A Guide to Using KBS Klean and RustBlast for Superior Adhesion
Properly preparing metal surfaces for painting is essential for achieving a durable, professional-looking finish. Without the correct preparation, paint can fail to adhere to metal, leading to peeling, rust, or uneven coverage. This guide covers the step-by-step process using two highly effective products: KBS Klean and RustBlast. We'll also cover factors that can limit adhesion and how to overcome them.
The Importance of Proper Surface Preparation
Before applying any paint to metal, you must clean and prepare the surface thoroughly. Metal surfaces often carry grease, oil, rust, dirt, and other contaminants that interfere with paint adhesion. Even a thin layer of residue can cause paint to peel prematurely.
Proper surface prep not only enhances adhesion but ensures the paint can protect the metal from corrosion, wear, and environmental damage. Follow the steps below for a surface that's ready for a beautiful, long-lasting finish — whether on outdoor equipment, automotive parts, or home decor.
Step-by-Step Process to Prepare Metal for Painting
Step 1 — Remove Loose, Flakey Rust
Remove any loose or flakey rust as a first step to provide a stable surface for coatings. This can be done with 320 grit sandpaper, a wire brush, or by sandblasting.
Step 2 — Clean the Surface with KBS Klean
Cleaning is vital because even a thin layer of dirt, grease, or oil will prevent paint from bonding to metal. KBS Klean thoroughly removes contaminants without leaving harmful residue the way solvent-based cleaners can.
Mix KBS Klean with warm water and scrub the metal surface with a sponge, scrub pad, or scrub brush. Rinse thoroughly with water, then dry completely with a clean, lint-free cloth or compressed air.
TIP
Avoid handling bare metal without gloves after cleaning. Skin oil transferred to the surface can cause paint to peel, bubble, or fail to adhere.
Detailed instructions for KBS Klean can be found on the directions page.
Step 3 — Remove and Neutralize Rust with RustBlast
Rust is one of the most common issues when preparing metal for painting. Left untreated, it prevents proper adhesion and continues to spread beneath the paint, causing premature peeling. RustBlast chemically dissolves and neutralizes rust — apply it directly to rusted areas and keep it wet, reapplying as needed:
  • Smooth or lightly rusted surfaces: minimum 30 minutes
  • Moderately rusted surfaces: 40–60 minutes
  • Heavily rusted or corroded surfaces: 1–2 hours
Intermittently scrub the surface with a scrub pad or scrub brush throughout the process to slough off loosened rust particles. The surface must always stay wet with RustBlast — do not allow it to dry. Once rust is removed, rinse thoroughly with water and allow the surface to dry completely.
IMPORTANT
After drying, a whitish powdery residue will remain on the metal. This is a zinc phosphate coating that enhances paint adhesion. Do not wipe it off — apply your paint or coating directly over it.
7-DAY COATING WINDOW
Apply paint or coating within 7 days of RustBlast treatment when the surface is kept covered, clean, and out of the elements. If more than 7 days pass, reapply RustBlast before coating.
Detailed instructions for RustBlast can be found on the directions page.
After RustBlast treatment, the metal is ready for coating.
Surface Profile
To maximize paint adhesion, the metal surface should have a roughness profile — often called an anchor pattern — that allows coatings to grip the texture peaks and valleys. Traditionally this is done by sanding or sandblasting, but RustBlast performs this function by chemically etching the surface, eliminating the need for mechanical abrasion. The zinc phosphate layer left behind further enhances paint adhesion.
Other Factors That Limit Paint Adhesion on Metal
Before applying paints or coatings to treated metal, consider these additional factors that can hinder adhesion:
Oils and Grease: Oils and grease are among the most common adhesion blockers. Handling bare metal without gloves leaves skin oil that can cause paint to peel, bubble, or fail to bond.
Moisture and Humidity: Moisture on the surface can prevent proper adhesion and allow rust to form beneath the paint. Ensure the metal is completely dry before painting. Avoid painting in high humidity or when the surface temperature is within 5°F of the dew point.
Airborne Contaminants: Dust, dirt, and airborne debris can settle on freshly cleaned surfaces and prevent paint from sticking. Clean the work area and paint in a well-ventilated space to minimize exposure.
Temperature Extremes: Metal that is too hot or too cold affects how paint dries and bonds. The ideal temperature for painting metal is typically 50°F to 85°F. Painting outside this range can cause uneven drying, poor adhesion, or finish defects.
TEMPERATURE GUIDE
RustBlast: Ideal working temp 55–90°F. Surface must stay wet — do not allow to dry during application.
Painting: Ideal temp 50–85°F. Avoid painting if surface temp is within 5°F of dew point.
Coating Metal Treated with RustBlast
Metal treated with RustBlast can be directly coated with a variety of paints, coatings, and primers — including surfaces with light residual surface rust. KBS Coatings products that apply directly over RustBlast-treated metal include:
BEST PRACTICE
For ultimate rust protection, apply RustSeal as your base coat over RustBlast-treated metal. RustSeal can then be top coated with BlackTop, KBS MAXX, KBS Top Coater, or KBS Top Coater Aerosol for a complete, durable finish.
Do I need to use both KBS Klean and RustBlast, or just one?
Both are recommended for best results on rusty metal. KBS Klean removes grease, oil, and dirt first — a critical step because contaminants block adhesion even after rust removal. RustBlast then removes and neutralizes rust while chemically etching the surface for better paint bonding. On new, rust-free metal with minimal contamination, KBS Klean alone may be sufficient.
What is the white powdery residue left on metal after RustBlast dries?
The white powdery residue is a zinc phosphate coating — a natural byproduct of RustBlast's acid-etching reaction. It improves paint adhesion and should not be wiped off. Apply your paint or coating directly over it within 7 days.
How long after using RustBlast do I have to apply paint or coating?
Apply paint or coating within 7 days of RustBlast treatment, provided the surface is kept covered, clean, and out of the elements. If more than 7 days pass, reapply RustBlast before coating.
Can I paint directly over RustBlast-treated metal without a primer?
Yes. RustBlast chemically etches the surface and leaves a zinc phosphate layer that functions as a pre-paint primer. KBS Coatings products including RustSeal, KBS MAXX, BlackTop, KBS Top Coater, and Motor Coater can all be applied directly to RustBlast-treated metal without an additional primer.
What is the ideal temperature for using KBS Klean and RustBlast?
The ideal working temperature for RustBlast is 55–90°F. For applying paint after surface prep, the recommended range is 50–85°F. Avoid working in high humidity or when the surface temperature is within 5°F of the dew point.
Questions?
If you have any questions about preparing metal for painting or which KBS Coatings products are right for your project, we're happy to help.
