Motor Coater - Picture of Easy-To-Apply Engine Paint
Motor Coater is a professional-grade, high-solids engine enamel engineered to deliver a deep, rich, factory-quality finish on automotive engines, brake calipers, and virtually any metal surface exposed to underhood heat. It self-levels to eliminate brush marks, matches original OEM colors exactly, and resists temperatures up to 500°F intermittently — all without blistering, flaking, cracking, or peeling.
What Makes Motor Coater Different?
OEM Color Match — Exact factory color formulations for a deep, rich finish that looks like it left the assembly line.
500°F Heat Resistance — Advanced ceramic resin system handles intermittent high engine temperatures without failure.
UV Stable & Exterior Grade — Will not discolor, chalk, or fade when exposed to sunlight and the elements.
Chemical Resistant — Stands up to oil, gasoline, transmission fluid, and other underhood fluids.
Self-Leveling Formula — Brush marks flow out for a smooth, spray-like professional finish — no special equipment needed.
Pro Tip: Great for Brake Calipers
Motor Coater's heat resistance and chemical durability make it an excellent choice for painting brake calipers. Its tough finish holds up to the punishment of repeated heating and cooling cycles.
Temperatures Above 500°F?
Motor Coater is not designed for exhaust headers, manifolds, or exhaust pipes. For those surfaces, use KBS XTC, which is rated from 500°F to 1,200°F.
Ready to Make Your Engine a Show Stopper?
Choose from 40+ OEM colors. Factory direct. Ships same day.
Shop Motor Coater High-Temp: Shop XTC Contact KBS Support
