The Best Way to Remove Paint from Metal
KBS Strip - Paint Remover
There are a variety of ways to remove paint from metal, including chemical methods like paint stripper, as well as abrasive techniques like media blasting, sanding, and wire wheeling. But which is best to use? Let's take a look at these methods, go over the pros and cons of each, and describe when they should be used.
What is Paint Stripper?
Paint stripper, also known as paint remover, is a chemical that's formulated to remove paint, varnish, and other coatings. Paint stripper breaks down and softens the paint while loosening it from the surface, which makes it far easier to scrape the paint away.
What Are the Benefits of Paint Stripper?
There are distinct pros to using paint stripper to remove paint from metal.
  • Increased Time Efficiency – As paint stripper breaks down and dissolves paint it makes the removal procedure more time efficient than mechanical techniques like sanding or wire wheeling. This is especially so when removing paint from intricate or detailed surfaces where manual methods can be a long and labor-intensive process.
  • Reduces Physical Exertion – Greatly decreases physical labor as compared to mechanical paint removal methods like sanding. This is a huge consideration when working with large or intricate surfaces.
  • Easy Access – Paint stripper can reach complex shapes and crevices that are difficult to access when sanding or using other abrasive paint removal methods.
  • Gentler on Some Metals – Chemical paint strippers are typically gentler on metal surfaces than abrasive methods. This helps prevent damage that could occur with aggressive mechanical paint removal techniques. However, keep in mind some types of metals can be damaged by paint stripper. See below.
What Are the Drawbacks of Paint Stripper?
There are also cons to using paint stripper to remove paint from metal.
  • Metal Damage – Metals like aluminum and some alloys can be sensitive to the corrosive effects of paint stripper. When in doubt about the compatibility of a paint stripper and metal, it's best to check the recommendations of the paint stripper.
  • Toxicity – Paint strippers are typically made of harsh chemicals. If these chemicals contact the skin they can cause irritation and burns. Also, fumes can cause respiratory distress if inhaled.
  • Pollution – Some paint strippers contain environmentally hazardous chemicals, and if not disposed of properly can contribute to air and water pollution.
  • Effectiveness – Some paint strippers are not equally effective on all types of paints and may need additional applications or alternative removal methods.
⚠ Safety Warning
Always wear chemical-resistant gloves and eye protection, and work in a well-ventilated area when using paint stripper. Avoid skin and eye contact — if exposure occurs, rinse immediately with water. Follow local regulations for proper disposal of used stripper and removed paint residue.
When Should Paint Stripper Be Used?
Here are some instances where it's advantageous to use paint stripper to remove paint from metal.
  • Complex Surfaces – Paint stripper can quickly and effectively remove paint from intricate or detailed surfaces, whereas sanding would be a time and labor-intensive process.
  • Antique or Vintage Workpieces – Paint stripper can be used to remove paint without causing the damage that can result with mechanical abrasion methods.
  • Short Project Timelines – Paint stripper allows paint to be removed more quickly than sanding.
  • Avoiding Dust and Debris – Media blasting, sanding, and wire wheeling create dust and particulate debris.
What is Media Blasting?
Media blasting is a process where abrasive particles are shot against a surface at high speed to remove contaminants, coatings, or unwanted materials. Different types of media are used for media blasting, and which is employed depends on the surface being treated.
The abrasive media most often used to remove paint from metal include sand, glass beads, walnut shells, aluminum oxide, and plastic pellets. The choice of abrasive, and the speed at which it is propelled, depends on the hardness of the surface, the type of material being removed, and the desired finish.
Media blasting can be done with sand blasters or bead blasters, which use compressed air or water pressure to shoot the abrasive particles against the surface.
What Are the Benefits of Media Blasting?
There are benefits to using media blasting to remove paint from metal, rather than other paint removal methods.
  • Effective Paint Removal – Media blasting is highly effective in removing paint, dirt, grease, oil, and other contaminants from metal surfaces.
  • Versatility – A variety of metals, including steel, aluminum, brass, and copper can be media blasted.
  • Increased Time Efficiency – Media blasting makes quick work of paint removal and is typically more time efficient than using paint stripper and a scraper, and mechanical techniques like sanding or wire wheeling. This is especially so when removing paint from intricate or detailed surfaces where sanding can be a long and labor-intensive process.
  • Anchor Pattern – The best adhesion of paints and coatings can be had if the metal surface is first textured with an "anchor pattern." An anchor pattern is a series of microscopic peaks and valleys that provide a foothold for the paint or coating. Media blasting provides this surface texturing.
★ Pro Tip
The anchor pattern created by media blasting is ideal for promoting strong coating adhesion. Once blasted, follow up with RustSeal to lock out moisture and stop corrosion before applying a topcoat.
What Are the Drawbacks of Media Blasting?
There are also cons to media blasting to remove paint from metal.
  • Dust and Debris – The blasting media creates fine airborne dust particles which can pose a health risk if inhaled. Also, the abrasive particles and debris from the metal surface can create quite a mess if not properly contained.
  • Abrasive Contact – The abrasive particles used in sandblasting can cause skin and eye irritation.
  • Over-Removal of Material – If precautions aren't taken, including choosing the correct abrasive media and the speed at which the media is propelled, the result can be the over-removal of material from the metal surface.
  • Media Cost – The cost of abrasive media used in media blasting can get expensive, especially for large-scale projects.
When Should Media Blasting Be Used?
Here are instances when it's most advantageous to use media blasting for removing paint from metal.
  • Large Areas – Media blasting greatly reduces labor, which is especially important when large surface areas need to be prepared.
  • Short Project Timelines – Media blasting allows paint to be removed more quickly than using paint stripper or sanding.
  • Thick Paint Coats – Media blasting is more effective for surfaces that have thick coats of paint as it can quickly and thoroughly remove it.
  • Complex Surfaces – Media blasting can quickly and effectively remove paint from intricate or detailed surfaces, whereas sanding would be a time and labor-intensive process.
  • Anchor Pattern – When etching an anchor pattern into the metal is desired.
What is Sanding and Wire Wheeling?
Sanding and wire wheeling are abrasive means of removing paint from metal and have major distinctions.
Sanding
Sanding is commonly done with sandpaper, abrasive pads, or abrasive tools and can be performed by hand and with power tools such as electric sanders. The abrasive nature of sandpaper helps remove old paint and coatings as well as smooth surfaces and remove imperfections.
The type of sandpaper used to remove paint from metal depends on the hardness of the metal. Aluminum oxide sandpaper is good for sanding hard metals like iron or steel, while silicon carbide sandpaper is appropriate for soft metals like aluminum and brass.
Choosing the correct sandpaper grit is equally important. It's recommended to use 320-grit or higher to sand metal. Keep in mind coarse grits will remove paint quickly but may leave a rough surface. Finer grit paper will remove paint more slowly but will be easier on the metal surface. For removing thick layers of paint, using a coarse grit paper to remove the top and mid-level of the paint layer, and switching to finer grit paper before the paint layer gives way to the metal surface is a safe way to more quickly remove paint while decreasing the resulting surface roughness.
Wire Wheeling
Wire wheeling involves using a rotating wire wheel attached to power tools like angle grinders or bench grinders. Wire wheeling is a great way to quickly remove paint from metal.
Wire wheel bristles can be made of carbon steel, brass, or other materials. Carbon steel bristles can be used with hard ferrous metals, such as iron and steel. Brass wire wheels should be used on soft, non-ferrous metals like aluminum and brass.
The wire bristle diameter of wire wheels ranges from fine to coarse. It is generally recommended to use very fine to fine wire for light applications and medium to coarse wire for heavy applications. Fine wire should be used for soft, non-ferrous metals like aluminum and brass.
What Are the Benefits of Sanding and Wire Wheeling?
There are pros to sanding and wire wheeling to remove paint from metal, rather than other paint removal methods.
  • Versatility – Sanding and wire wheeling can be used on a variety of metal surfaces, including curved or uneven surfaces.
  • Increased Time Efficiency – Wire wheeling gets the job done quickly. However, sanding, especially sanding without power equipment, can be less time efficient.
  • Controlled Metal Removal – Sanding allows strict control over the amount of metal removed. This is especially helpful when dealing with delicate surfaces or intricate details where excessive removal could damage the metal. In contrast, wire wheeling may not allow as strict control of the amount of metal removed.
  • No Harmful Chemicals – No toxic chemicals are used for sanding or wire wheeling.
  • Cost Efficiency – Sandpaper is somewhat inexpensive compared to some other paint removal methods. Wire wheels, however, are a bit more expensive.
What Are the Drawbacks of Sanding and Wire Wheeling?
There are also disadvantages to sanding or using a wire wheel to remove paint from metal.
  • Dust and Particles – Sanding and wire wheeling metal can create a substantial amount of dust and small metal particles which can cause respiratory problems, as well as create a mess as they settle.
  • Surface Damage – Forceful sanding and wire wheeling can create scratches on the metal surface. Using the wrong grit of sandpaper or wire bristle diameter, as well as applying too much pressure, can contribute to this problem.
  • Over-Removal of Material – Wire wheeling can result in over-removal of material from the metal surface if precautions aren't taken, including choosing the correct wire bristle diameter.
  • Sometimes Labor Intensive – Hand sanding without power tools can be time consuming and labor intensive.
  • Safety – Wire wheels can shed wires during use, and these wires can be sharp and cause injuries if they come into contact with skin.
  • Metal Contamination – If the metal being worked on is ferrous, the wire wheel can leave behind small particles that may rust over time if not properly cleaned and treated.
When Should Sanding and Wire Wheeling Be Used?
Here are instances when it's most advantageous to use sanding or wire wheeling to remove paint from metal.
  • Thick Paint Coats – Wire wheels are effective in quickly removing thick layers of paint.
  • Large Areas – Wire wheeling can cover large areas more rapidly compared to hand sanding.
  • Fine Details – Sanding is often preferred for finer details and when a smoother finish is desired.
  • Budget Constraints – Sanding equipment is often more readily available and may be a more cost-effective option for small to medium-sized projects.
  • Flaking Paint – When the project only requires removing loose and flaking paint, sanding or wire wheeling makes the most sense.
Paint Removal Technique Combinations
In many cases, a combination of methods to remove paint from metal might be used. For instance, media blasting could be used to remove heavy rust and contaminants, followed by sanding for finer finishing. Ultimately, the decision should be based on the specific requirements of the project, considering factors like the type of metal, the condition of the surface, the level of precision needed, and the available equipment and resources.
★ Pro Tip: Complete the Job Right
After stripping old paint, proper surface prep is the key to lasting results. The full KBS system — degrease with KBS Klean, etch with RustBlast, and seal with RustSeal — ensures bare metal is perfectly prepared for long-lasting topcoat adhesion.
Ready to Strip Old Paint?
KBS Strip is a professional-strength paint remover designed for metal surfaces. Have questions about your project? Our team is here to help.
Shop KBS Strip    Contact Us
