Using Bed Liner on Rocker Panels, Doors, And Fenders for Protection
KBS Bed Liner applied to rocker panels and body panels
Using Bed Liner on Rocker Panels, Doors, and Fenders for Protection
Off-road enthusiasts frequently ask about a coating that will protect body panels from rocks, tree branches, and trail debris. Applying KBS Bed Liner on rocker panels, doors, fenders, and other body panels is a proven and effective way to prevent this type of damage.
Ready to protect your body panels?
KBS Bed Liner is available in quart and gallon sizes. KBS Bed Renu aerosol is also available for smaller jobs and touch-ups.
Shop KBS Bed Liner
Benefits of Using Bed Liner to Protect Body Panels
KBS Bed Liner protects body panels with a tough, flexible, thick coating that can withstand impacts from rocks, branches, and other debris. This protects against dings and deep scratches that leave metal exposed — the entry point for rust.
KBS Bed Liner adheres strongly to both painted and bare metal surfaces to deliver a highly durable, long-lasting finish. The satin black coating is chip and scratch resistant, UV stable, and chemical resistant. As a bonus, it hides minor bodywork imperfections.
KBS Bed Liner at a Glance
✓  Tough, flexible, impact-resistant coating
✓  Chip and scratch resistant
✓  UV stable — will not fade in sunlight
✓  Chemical resistant
✓  Adheres to painted and bare metal surfaces
✓  Hides minor bodywork imperfections
What Body Panels Can Be Protected with KBS Bed Liner?
KBS Bed Liner can be used to shield a wide variety of areas, including:
  • Rocker panels
  • Fenders
  • Fender flares
  • Lower door panels
  • Bumpers
  • Hoods
Some customers have even coated the complete body of their vehicle for maximum protection and a dramatic look.
How to Apply Bed Liner on Rocker Panels, Lower Door Panels, Fenders, and More
KBS Bed Liner requires no complicated mixing and is simple to apply. It can be brushed, rolled, or applied with spray equipment. KBS Bed Renu is a convenient aerosol version for smaller areas and touch-ups.
Painted Surfaces with No Exposed Metal or Rust
When applying KBS Bed Liner on rocker panels, lower door panels, and other painted surfaces with no exposed metal or rust, follow this procedure to ensure proper adhesion:
  1. Wash the surface with soap and water, or KBS Klean diluted 5 parts hot water to 1 part KBS Klean. This concentrated cleaner removes dirt, grease, and contaminants without leaving residue that can interfere with adhesion. See full KBS Klean application instructions.
  2. Rinse with clean water and dry thoroughly.
  3. Mask off areas not to be coated.
  4. Scuff painted surfaces with medium-grit sandpaper or a scouring pad.
  5. Wash again with KBS Klean (5:1 dilution).
  6. Rinse with clean water and dry thoroughly.
  7. The surface must be clean, bone dry, and non-glossy before application.
  8. Apply 2–3 coats of KBS Bed Liner. Start with a thin first coat to provide a base for adhesion — this prevents the product from running or sagging on vertical surfaces. Follow with a slightly heavier coat. See full KBS Bed Liner application instructions.
Surfaces with Exposed Metal, Loose or Flaky Paint, and/or Rust
If a surface has exposed bare metal, rust, or loose/flaky paint, additional preparation steps are required before applying KBS Bed Liner:
  1. Wash the surface with soap and water, or KBS Klean (5 parts hot water to 1 part KBS Klean).
  4. Remove loose, flaky paint and rust with sandpaper, a wire brush, or wire wheel.
  5. Wash again with KBS Klean.
  7. Scuff any remaining paint with medium-grit sandpaper or a scouring pad.
  8. The surface must be clean, bone dry, non-glossy, and free of rust or flaking paint before application.
  9. Apply KBS Bed Liner as described above.
For the ultimate protection against rust, use the KBS 3-Step System before applying Bed Liner on rocker panels, fenders, doors, and other body panels. This system also applies to surfaces with firmly adhered paint, exposed bare metal, or rust.
The KBS 3-Step Rust Prevention System
The KBS 3-Step System consists of three products used in sequence to clean, treat, and permanently seal metal against rust:
Step 1 — KBS Klean
A powerful concentrated water-based cleaner and degreaser that removes dirt, grease, and contaminants without leaving adhesion-inhibiting residue.
Step 2 — RustBlast
Removes rust, acts as a zinc phosphate pre-primer, and etches metal for the best adhesion of RustSeal.
Step 3 — RustSeal
A high-performance, single-part, ready-to-use rust preventive coating. RustSeal is impervious to road salts and most chemicals. It flows out to a rock-hard, tough, ceramic-like finish that will not crack or peel, and can be applied by brush, roller, or spray equipment.
Note: It is not necessary to remove every last bit of rust before applying RustSeal. RustSeal bonds to and permanently seals remaining flash rust or corrosion. After RustBlast, a slight white powder residue may appear — this is a zinc phosphate coating that is beneficial for RustSeal adhesion. Some flash rust or orange staining may occur if the surface was soaked and not dried immediately after RustBlast; this is normal and you can proceed with RustSeal.
Procedure for Surfaces with No Loose or Flaky Paint, No Exposed Metal, and No Rust
  4. Scuff paint with medium-grit sandpaper or a scouring pad for best adhesion. (Note: RustBlast is not used in this procedure since there is no rust or exposed metal.)
  5. Wash the surface with KBS Klean.
  8. Apply RustSeal per the RustSeal application directions.
  9. Let the final coat of RustSeal fully cure (at least 24 hours), scuff with 320-grit sandpaper, then apply KBS Bed Liner.
Procedure for Surfaces with Loose or Flaky Paint, Exposed Metal, and/or Rust
  7. Scrub with RustBlast and a scrub pad. See full rust prevention directions.
  8. Rinse with clean water and dry thoroughly.
  9. Scuff any remaining paint with medium-grit sandpaper or a scouring pad.
  10. Wash the surface with KBS Klean.
  11. Rinse with clean water and dry thoroughly.
  12. The surface must be clean, bone dry, non-glossy, and free of rust or flaking paint before application.
  13. Apply RustSeal per the RustSeal application directions.
  14. Let the final coat of RustSeal fully cure (at least 24 hours), scuff with 320-grit sandpaper, then apply KBS Bed Liner.
Get Everything You Need
Shop KBS Bed Liner and the complete KBS 3-Step System — KBS Klean, RustBlast, and RustSeal — for the highest level of protection against rust and damage.
Shop KBS Bed Liner Shop the 3-Step System
Can I apply KBS Bed Liner directly over painted surfaces?
Yes. Clean the surface with KBS Klean, scuff with medium-grit sandpaper or a scouring pad, clean again, and apply 2–3 coats of KBS Bed Liner. The surface must be clean, bone dry, and non-glossy before application.
Do I need to use RustSeal before applying KBS Bed Liner on rusty rocker panels?
Yes, if the surface has exposed bare metal or rust. For the best results, use the KBS 3-Step System: clean with KBS Klean, treat with RustBlast, apply RustSeal, let it fully cure (at least 24 hours), scuff with 320-grit sandpaper, then apply KBS Bed Liner.
How many coats of KBS Bed Liner should I apply?
Apply 2–3 coats. Start with a thin first coat to create a base that prevents running or sagging on vertical surfaces. Follow with a slightly heavier coat. A third coat can be added for additional texture and protection.
What body panels can KBS Bed Liner be applied to?
KBS Bed Liner can be applied to rocker panels, fenders, fender flares, lower door panels, bumpers, hoods, and more. Some customers coat the entire vehicle for maximum protection and a dramatic look.
Can KBS Bed Liner be sprayed?
Yes. KBS Bed Liner can be applied by brush, roller, or spray equipment. KBS Bed Renu is also available as a convenient aerosol version, ideal for smaller areas and touch-ups.
Is KBS Bed Liner UV stable?
Yes. KBS Bed Liner is UV stable and resists fading and degradation from sunlight. The satin black finish remains chip and scratch resistant over time.
What is the KBS 3-Step System?
The KBS 3-Step System is a complete rust prevention system consisting of KBS Klean (cleaner/degreaser), RustBlast (rust remover and metal etch), and RustSeal (permanent rust preventive coating). When used before KBS Bed Liner, it provides the highest level of protection against rust and corrosion.
Questions?
Not sure which procedure is right for your project, or have questions about using bed liner on rocker panels, doors, and fenders? Our team is happy to help.
Get Expert Help from KBS Coatings
Contact us and we'll help you choose the right products and procedure for your project.
Contact KBS Coatings
