XTC And XTC Clear Used To Paint Smoker
Smoker painted with XTC high temperature coating and XTC Clear gloss topcoat
XTC and XTC Clear Used to Paint a Smoker
XTC is a high temperature/heat-resistant coating formulated specifically to protect metal surfaces operating at temperatures from 500°F to 1500°F, making it ideal for smokers and grills. With proper preparation, XTC provides outstanding adhesion, film integrity, weathering, and thermal shock resistance throughout this entire temperature range, and it's guaranteed not to burn off. XTC is ideal for exterior applications because it resists rust when primed with XTC Primer.
XTC at a Glance
✓  Withstands continuous temperatures up to 1500°F
✓  Guaranteed not to burn off
✓  UV stable — won't chalk or fade
✓  Can be brushed, rolled, or sprayed
✓  Available in 12 colors, including Clear
XTC Clear is a gloss clear option in the XTC color line, typically applied over an XTC base color to provide the gloss finish many customers want for their smoker. Using XTC Clear over a base color adds depth and shine while keeping the same high-heat protection.
Why XTC Works for Smokers and Grills
Smokers and grills see repeated cycles of intense heat, moisture, and outdoor exposure — conditions that cause ordinary paint to blister, chalk, or burn off. XTC is a silicone-based coating engineered specifically for this kind of sustained high-heat environment, whether it's a firebox, smoke chamber, or exterior shell.
Is XTC good for painting a smoker?
Yes. XTC is a silicone-based, heat-resistant coating rated for continuous temperatures from 500°F to 1500°F, making it ideal for smokers, grills, wood and pellet stoves, and other high-heat metal surfaces. It resists chalking, fading, and burning off.
What is XTC Clear used for?
XTC Clear is a gloss clear option within the XTC color line, typically applied over an XTC base color to add shine and a finished look to smokers, grills, and other high-heat projects.
Do I need XTC Primer under XTC on a smoker?
XTC Primer is not required for adhesion, but it is recommended for rust protection on exterior applications like smokers that are exposed to the elements.
Will XTC burn off on a smoker or grill?
No. XTC is guaranteed not to burn off within its rated temperature range of 500°F to 1500°F, and it maintains adhesion, film integrity, and thermal shock resistance across that entire range.
Ready to Paint Your Smoker?
XTC is available in 12 colors, including Clear, and ships factory direct the same day.
Shop XTC Ask a Question
