Rust Prevention Products Used To Stop and Prevent Rust on Car Surfaces
▶ Featured Video — Stacey David: Stop and Prevent Rust on Car Surfaces
Stacey David shows how easy it is to prep and coat surfaces of your car or vehicle to stop rust and prevent rust from destroying the metal surfaces, using the KBS Coatings rust prevention system.
In the video, Stacey David shows how easy it is to prep and coat surfaces of your car or vehicle to stop rust and prevent rust from destroying the metal surfaces. The rust prevention system from KBS Coatings, that features KBS Klean, RustBlast, and RustSeal, is used to stop rust and prevent rust on all of these surfaces and more: suspension mounts, strut towers, control arms, shocks and struts, sway bars, backend exhaust, exhaust pipes, catalytic converters, mufflers, rocker panels, floor boards, trunk floors, front fenders, rear fenders, doors, battery compartment, engine compartments, and engine bays.
Why RustSeal Stops Rust
RustSeal is a superior one part, completely non-porous, ready-to-use, high-solid content, rust preventive coating, that is actually strengthened by exposure to moisture. It is impervious to road salts and most every chemical.
RustSeal flows out to a beautiful, rock-hard, tough coating that is tough to chip or scratch. These exceptional properties make RustSeal specifically formulated to prevent corrosion and stop rust.
RustSeal completely seals metal surfaces, blocking all the pores and preventing penetration of moisture, oxygen, and water vapor.
Unlike other corrosion treatments, RustSeal is an enhancement and investment that lasts. Water and air are locked out, therefore oxidation, the precursor to rust, cannot take hold on the metal surfaces of your vehicle.
What products make up the KBS rust prevention system shown in this video?
KBS Klean cleans and degreases, RustBlast dissolves rust and preps the metal, and RustSeal permanently seals the surface against moisture and oxygen.
What car and vehicle surfaces can this system be used on?
Suspension mounts, strut towers, control arms, shocks and struts, sway bars, exhaust pipes, catalytic converters, mufflers, rocker panels, floor boards, trunk floors, fenders, doors, battery compartments, and engine bays.
How does RustSeal stop rust from forming?
It seals metal surfaces and blocks pores, keeping moisture, oxygen, and water vapor out. Since oxidation needs both moisture and oxygen, locking them out keeps rust from taking hold.
Ready to stop rust on your vehicle?
Shop RustSeal    Contact Our Tech Team
