Using RustSeal Safety Colors for Painting Industrial Equipment and Floor Markings
Safety color paint is used regularly in industrial environments to enhance visibility, identify hazards, and promote workplace safety. But safety colors placed on equipment and floors take a beating — and the paint needs to keep up. It must protect against corrosion, hold up to abrasion, impacts, and chemical exposure, and still look sharp over time. RustSeal is built to do exactly that, and it's available in OSHA-compliant safety colors for industrial use.
RustSeal is an advanced moisture-cured coating that seals surfaces against rust and corrosion. It bonds strongly to porous surfaces like concrete, and because it is a single-part coating, it is easy to apply. RustSeal flows out to a beautiful, rock-hard, ceramic-like finish that is impervious to nearly every chemical, tough to chip or scratch, and will not crack or peel.
Why RustSeal Works for Safety Color Applications
RustSeal does double duty — it creates safety awareness AND protects the coated surface. It can be applied with a brush, roller, or spray equipment, and adheres to metals, concrete, plastic, fiberglass, and ceramic. One coating handles it all.
RustSeal is offered in Safety Yellow, Safety Blue, and Safety Green — formulated to meet OSHA Safety Color standards for industrial equipment and floor marking applications.
RustSeal Safety ColorPrimary Industrial Use
Safety YellowCaution, warning, and marking physical hazards — forklifts, barriers, floor lanes, conveyor zones
Safety BlueNon-hazardous areas, safe pathways, pipe marking, storage — and informational floor guidance
Safety GreenEmergency exits, safe routes, first aid locations, safety information
What Are Commonly Used Safety Colors for Industrial Equipment and Floor Markings?
The following safety colors are widely used in industrial facilities to communicate hazard levels and guide safe behavior. While the full range of safety colors includes five standard colors, RustSeal is available in Safety Yellow, Safety Blue, and Safety Green.
ColorCommon Use
Safety RedFire protection equipment or emergency shutdown controls
Safety YellowCaution, warning, or marking physical hazards
Safety OrangeWarning or caution and highlighting potential hazards
Safety BlueNon-hazardous areas, safe pathways, locations of emergency equipment, or other important information
Safety GreenSafe routes, location of emergency exits, safety information
What Indoor Industrial Equipment Is Coated With Safety Colors?
RustSeal Safety Color paint can be used to identify and protect a variety of indoor industrial equipment.
Lifting and Handling Equipment
Applications include forklifts, pallet jacks, cranes, scissor lifts, and electric tuggers. Commonly used colors are safety red and safety yellow.
Safety Barriers and Rails
Applications include guardrails, crash barriers, retractable safety barriers, warehouse rack guards, and handrails. Commonly used colors are safety yellow, safety orange, and safety red.
Pipe and Valve Marking
Applications include pipes, valves, or other components marked as part of a color-coded system for easy identification. Commonly used colors are safety blue, safety green, and safety yellow.
Storage and Shelving
Applications include pallet racking systems, shelving units, bulk storage racks, and industrial cabinets and drawers. Commonly used colors are safety blue and safety green.
Emergency Stop Buttons
Applications include emergency stop buttons on manufacturing equipment. Safety red is the standard color for this application.
What Safety Colors Are Used for Floor Markings?
RustSeal Safety Colors can be used as floor marking paint and for safety line painting.
Fire Equipment and Danger
Designate fire equipment and areas with potential danger. Safety red is used for this application.
Conveyor Systems
Mark loading zones, emergency stop points, or areas where caution is required. Safety yellow is the commonly used color.
Non-Hazardous Areas
Designate non-hazardous areas within a facility where safety precautions are not as critical. Safety blue is the commonly used color.
Informational Guidance
Designate informational guidance — such as indicating the direction to emergency exits or safety equipment. Safety blue is the commonly used color.
Safety and First Aid
Highlight safety-related items and first aid locations. Safety green is used for this application.
Traffic and Housekeeping
Designate traffic lanes, pedestrian walkways, and general housekeeping areas. Commonly used colors are safety yellow, white, and black.
RustSeal Safety Colors Identify and Protect
RustSeal Safety Colors create safety awareness and protect coated surfaces at the same time. RustSeal seals metal from moisture and oxygen to prevent rust and corrosion. On concrete floors, it seals the surface against moisture and contaminants. And because RustSeal adheres to so many different materials, it is a single-product solution for coating a variety of surfaces throughout a facility.
Built for Industrial Abuse
RustSeal is tough to chip or scratch and will not crack or peel — maintaining its safety color visibility and corrosion protection long after application.
Safety Colors in Aerosol
When a project calls for the convenience of an aerosol can, KBS Top Coater Aerosol is available in Safety Colors. It adheres very well to equipment surfaces that have been cleaned with KBS Klean. Keep KBS Top Coater Aerosol in mind when the project requires the convenience of spray-can application.
What safety colors does RustSeal come in?
RustSeal is available in Safety Yellow, Safety Blue, and Safety Green. All three are formulated to meet OSHA Safety Color standards for industrial equipment and floor marking applications.
Does RustSeal Safety Colors meet OSHA standards?
Yes. RustSeal Safety Colors are formulated to meet OSHA Safety Color standards for use in industrial environments.
Can RustSeal be used as floor marking paint?
Yes. RustSeal bonds strongly to concrete and seals it against moisture and contaminants, making it well-suited for floor marking paint and safety line painting. Its ceramic-like finish resists abrasion and chemical exposure.
What surfaces can RustSeal Safety Colors be applied to?
RustSeal can be applied to ferrous and non-ferrous metals, concrete, plastic, fiberglass, and ceramic — making it a single-product solution for coating a variety of industrial surfaces.
How is RustSeal applied?
RustSeal can be applied with a brush, roller, or spray equipment. This flexibility makes it practical for small touch-up work and large industrial coating projects alike, minimizing downtime.
Is there a safety color aerosol option from KBS Coatings?
Yes. KBS Top Coater Aerosol is available in Safety Colors and is a convenient option for equipment surfaces that have been cleaned with KBS Klean.
Ready to Order RustSeal Safety Colors?
Available in Safety Yellow, Safety Blue, and Safety Green — formulated to meet OSHA standards and protect against rust, abrasion, and chemical exposure. Order direct and we ship same day.
Shop RustSeal Safety Colors Ask a Question
