DiamondFinish Clear Aerosol Used To Clear Coat Wooden Steering Wheel
DiamondFinish Clear Aerosol is an excellent clear coat to go over sealed wood. DiamondFinish Clear Aerosol is very easy to apply achieving professional looking results. DiamondFinish Clear Aerosol creates a durable finish that withstands all sorts of abuse without chipping, cracking, or peeling making it ideal to apply in some of the toughest environments.
“The original finish was a furniture lacquer that only lasted about two years before getting sticky and unable to clean. I removed the old finish by first scraping because it fouled the sandpaper very quickly. I then sanded the wood down to 320 grit. I applied 3 coats of DiamondFinish Clear Aerosol using 4 passes each time. With 24hr drying. Then sanded each with 320 grit. I then applied 3 coats about 20 minutes apart and let it cure for 48+hrs. Then wet sanded with 320, 400,600, 800, 1000, 1500. Then hand buffed to final shine. I am very happy with the results and everyone in shows and cruises is amazed at the finish.” -Ed M.
