Rust Protection - Rust Prevention
What's The Best Rust Preventive Coating?
How does RustSeal compare with cold galvanizing compounds and zinc-rich coatings for rust protection? The primary purpose of all these coatings is to protect metal against rust — and all can be applied with a roller, brush, or spray equipment. However, RustSeal prevents rust and corrosion in a very different way than zinc-based coatings — and that difference matters for long-term performance.
What are cold galvanizing compounds?
Cold galvanizing compounds are coatings that contain zinc particles and are used to provide corrosion protection on metal surfaces. Cold galvanizing is a term used to describe the application of a zinc-rich coating without the need for hot-dip galvanizing, which involves immersing the metal in molten zinc.
Cold galvanizing compounds are often used for touch-ups, repairs, or as a quick corrosion protection solution for steel surfaces. They are commonly applied in the field where hot-dip galvanizing may not be practical.
The primary active ingredient of cold galvanizing compounds is zinc dust or zinc powder. Zinc is a corrosion-resistant metal and serves as a sacrificial anode — it corrodes in place of the underlying steel or iron.
How Does a Sacrificial Anode Work?
A sacrificial anode is made from a metal that is more reactive to corrosion than the metal it is protecting. Based on galvanic corrosion principles, the more reactive metal (zinc) sacrifices itself — corroding first so the underlying iron or steel doesn't have to. The protection only lasts as long as the zinc supply holds out.
What are zinc-rich coatings?
Zinc-rich coatings include cold galvanizing compounds but also encompass other zinc-impregnated products — such as epoxy or polyurethane zinc-rich coatings — used for industrial structures, pipelines, marine environments, and more. Like cold galvanizing, all zinc-rich coatings use zinc as a sacrificial anode to prevent rust on ferrous metal surfaces.
What is RustSeal?
RustSeal is a single-part (no activator required), moisture-cured, high-solids rust preventive coating. When applied, RustSeal flows out to a beautiful, rock-hard, ceramic-like finish that is tough to chip or scratch and will not crack or peel. It has exceptional adhesion to prepped bare metal (ferrous and non-ferrous) and prepped galvanized surfaces.
Why RustSeal's Approach Is Different
While zinc-based coatings prevent rust by consuming zinc as a sacrificial agent, RustSeal forms a permanent, non-porous barrier against moisture and oxygen. Without moisture and oxygen, metal cannot rust. That means lifetime protection — not a finite window that expires when the zinc runs out.
How does RustSeal compare against zinc coatings?
Here is how RustSeal outperforms zinc-based coatings across every major performance category.
Surface Preparation
Whether prepping metal for RustSeal, cold galvanizing compounds, or zinc-rich coatings, the surface must be clean and free of contaminants. However, zinc coatings require all rust to be fully removed before application. RustSeal can be applied over light surface rust to stop it in place and prevent future rust — saving significant preparation time and labor.
Pro Tip
Remove all loose, flaking, or scale rust before applying RustSeal. Light flash rust can stay — RustSeal will stop and encapsulate it. Zinc coatings require a rust-free surface before application.
Appearance
Zinc-rich coatings are typically not as smooth or aesthetically pleasing as RustSeal — which can matter in applications where appearance is important. Sacrificial corrosion also causes the look of zinc coatings to degrade over time. Because RustSeal is a permanent coating, it maintains its original ceramic-like finish quality indefinitely.
Maintenance
Galvanic protection relies on the depletion of zinc to protect the underlying metal. As the zinc is consumed, the protective capability of cold galvanizing compounds and zinc-rich coatings diminishes — eventually requiring reapplication or touch-up. RustSeal is a permanent coating that maintains its high-performance characteristics for the lifetime of the coated surface, with no periodic reapplication needed.
Coverage and Immersion
Cold galvanizing compounds and zinc-rich coatings may not provide as thick a protective layer as RustSeal — and coating thickness directly affects long-term corrosion resistance. Zinc coatings are also generally not suitable for applications where metal is constantly immersed in water, because continuous immersion accelerates zinc depletion. RustSeal's impermeable barrier keeps water away from metal even under constant immersion, making it the clear choice for tanks, submerged components, and marine applications.
Non-Ferrous Metals
Non-ferrous metals — such as aluminum, copper, and brass — do not contain iron and do not benefit from zinc's galvanic protection. Zinc-based coatings offer no corrosion protection on non-ferrous surfaces. RustSeal is equally effective sealing both ferrous and non-ferrous metals from corrosion, making it a single solution across all metal types.
Head-to-Head Comparison
CategoryRustSealZinc Coatings
Protection TypePermanent barrierSacrificial (finite)
Light Rust OK?YesNo — must remove all rust first
Non-Ferrous MetalsYesNo galvanic benefit
Constant ImmersionYesGenerally not suitable
Reapplication NeededNoYes — zinc depletes over time
Appearance Over TimeMaintains finishDegrades as zinc corrodes
Conclusion
Cold galvanizing compounds and zinc-rich coatings have long provided critical rust protection — and in their time, they were among the best options available. But coating technology has advanced significantly. Zinc-based coatings are a sacrificial system with a built-in expiration date. Once the zinc is consumed, the protection is gone. RustSeal uses modern high-solids resin technology to form a permanent non-porous barrier — sealing metal from the moisture and oxygen that cause rust, for the lifetime of the surface.
Can RustSeal be applied over light surface rust?
Yes. Unlike cold galvanizing compounds and zinc-rich coatings, RustSeal can be applied directly over light surface rust. Remove all loose scale and flaking, but you do not need to take the surface back to bare metal — saving significant preparation time and labor.
How long does RustSeal's rust protection last?
RustSeal forms a permanent, non-porous barrier that blocks moisture and oxygen from reaching the metal. Because it does not rely on a sacrificial material that depletes over time, RustSeal provides lifetime rust protection as long as the coating film remains intact.
Does RustSeal work on non-ferrous metals like aluminum and copper?
Yes. RustSeal bonds to both ferrous (iron and steel) and non-ferrous metals (aluminum, copper, brass, and more). Zinc-rich coatings rely on galvanic protection, which only benefits ferrous metals — they offer no corrosion protection on non-ferrous surfaces.
Can RustSeal be used in underwater or constant-immersion applications?
Yes. RustSeal's impermeable barrier keeps water away from metal even under continuous submersion. Cold galvanizing compounds and zinc-rich coatings are generally not suitable for constant immersion because water accelerates sacrificial zinc depletion.
Do I need to remove all rust before applying RustSeal?
Remove all loose, flaking, or scale rust. Light surface (flash) rust can remain — RustSeal will stop and encapsulate it. Cold galvanizing compounds and zinc-rich coatings require all rust to be fully removed before application.
Ready to Stop Rust for Good?
RustSeal is a permanent barrier coating — no zinc to deplete, no reapplication needed. Order direct and we ship same day.
Shop RustSeal Ask a Question
