Prepping and Sealing Marine Metal: RustSeal, Surface Prep, and a UV-Stable Topcoat
Marine metal prepped and sealed against rust with the KBS 3-Step System
Marine environments are brutal on metal. Boat trailers, hulls, decks, masts, and storage lockers are constantly exposed to salt, moisture, and sun, and once paint wears through and metal is exposed, rust sets in fast. Sealing marine metal properly means getting three things right: surface prep, a rust-proof barrier coat, and — if the piece will sit in direct sun — a UV-stable topcoat to protect the finish.
Quick Answer
Clean the surface with KBS Klean, etch and de-rust it with RustBlast, seal it with RustSeal (works above or below the waterline), and topcoat with KBS Top Coater if the piece will see direct sun. The KBS All-In-One Kit bundles everything needed for up to 50 sq. ft.
Step 1 — Prepare the Surface
To achieve the best bond, corrosion and organic contaminants need to be fully removed so RustSeal can penetrate and permanently adhere. The surface also needs a texture, or etch, that gives the coating something to grip. Sandblasting achieves this directly, but blasting with plastic, bead, or soda media doesn't provide enough abrasion on its own for direct RustSeal application.
If you're not sandblasting, use KBS Klean and RustBlast instead. KBS Klean is a concentrated, water-based, biodegradable, non-flammable cleaner that removes dirt, grime, oils, lubricants, grease, waxes, scum, algae, and other contaminants — apply it after using 320-grit sandpaper or a wire brush/wheel to remove loose, flaky rust. Once the surface is clean, RustBlast, a powerful rust remover, zinc phosphate pre-primer, and metal etch, dissolves rust, corrosion, metal oxides, and tarnish from most metal surfaces and etches the metal so RustSeal can penetrate deeper into the pores for a stronger seal.
KBS Klean cleaning marine metal before rust sealing
Step 2 — Seal It with RustSeal
RustSeal is a single-part, moisture-cured rust preventive coating engineered for exactly this kind of exposure. Its formulation is non-porous and impervious to air, water, sea salt, and chemicals, and it can be used above or below the waterline — protecting metal that's underwater or exposed to constant high humidity, like bilges, chain lockers, and fuel tanks.
PropertyWhy It Matters for Marine Use
Non-porous barrierBlocks air, water, and sea salt from reaching the metal underneath.
Flexible, hard finishStays bonded through dents and impacts, and as the metal expands and contracts.
Self-leveling applicationBrush, roll, or spray on for a smooth finish without brush marks, in 10+ colors.
Waterline-ratedSafe for continuous submersion or constant high humidity — hulls, bilges, tanks.
RustBlast etching marine metal for RustSeal adhesion
Step 3 — Topcoat for UV Protection
RustSeal isn't designed to be a final cosmetic marine finish — long-term direct UV exposure will fade its color and sheen over time, even though the rust protection underneath won't degrade. For surfaces that see regular sun, topcoat RustSeal with an opaque (solid color) paint system. KBS Top Coater is a popular choice: a single-part, high-solids paint that doesn't run or sag and delivers roughly twice the coverage of conventional single-part marine paint, brushed, rolled, or sprayed on with a self-leveling, professional-looking finish. It's available in 18 colors across gloss and matte finishes.
Pro Tip
If a topcoat isn't in the budget or plan, RustSeal alone still fully protects the metal from rust — you're only trading long-term color/gloss retention for simplicity, not rust protection.
KBS All-In-One Kit contents for prepping and sealing marine metal
The Full System in One Kit
The All-In-One Kit bundles everything needed to prep, seal, and topcoat marine metal in one order: KBS Klean, RustBlast, RustSeal, KBS Top Coater, #1 Thinner, brushes, gloves, and a stir stick — enough to cover up to 50 sq. ft. (two coats of RustSeal, 1–2 coats of Top Coater). Marine applications include engine rooms, hulls, masts, bilges, heat exchangers, decks, chain lockers, pumps, fuel tanks, and boat trailers.
Do I need to sandblast marine metal before applying RustSeal?
Sandblasting provides the ideal surface profile, but it isn't required. If you aren't sandblasting, use KBS Klean to clean the surface, then RustBlast to remove rust and etch the metal for adhesion. Blasting with plastic, bead, or soda media does not provide enough abrasion for direct RustSeal application.
Can RustSeal be used below the waterline?
Yes. RustSeal is non-porous and impervious to water, sea salt, and chemicals, and it can be used above or below the waterline on hulls, bilges, and other constantly submerged or humid surfaces.
Why do I need a topcoat over RustSeal on a boat?
RustSeal is not designed as a final cosmetic marine finish — long-term direct UV exposure will fade its color and sheen over time, though its rust protection does not degrade. Topcoating with KBS Top Coater protects the color and gloss of the finish while RustSeal continues to do the rust-sealing work underneath.
What does the KBS All-In-One Kit include for a marine project?
The All-In-One Kit includes KBS Klean, RustBlast, RustSeal, KBS Top Coater, #1 Thinner, brushes, gloves, and a stir stick — enough to prep, seal, and topcoat up to 50 sq. ft. of marine metal in one kit.
Ready to Protect Your Marine Metal?
The All-In-One Kit has everything you need to prep, seal, and topcoat up to 50 sq. ft. Order direct and we ship same day.
Shop the All-In-One Kit Shop RustSeal
