Will DiamondFinish Clear Adhere to Painted Aluminum Camper Siding?
Yes, DiamondFinish Clear will adhere to painted aluminum camper siding, as long as the existing paint is fully cured and properly prepped first. DiamondFinish Clear is a 1K moisture-cured urethane designed to bond directly to cured paint finishes, including the enamel and acrylic topcoats commonly used on RV and camper siding, without requiring a primer or adhesion promoter.
Why DiamondFinish Clear Bonds to Painted Aluminum
DiamondFinish Clear is a single-component, moisture-cured urethane clear coat with over 60% solids. It's built to apply directly to painted surfaces with minimal prep, and once cured it stays permanently flexible while resisting UV yellowing, cracking, and peeling. That combination, high solids for a strong bond, UV stability for constant sun exposure, and flexibility for a panel that expands and contracts, is what makes it a good fit for exterior camper siding rather than just automotive or shop projects.
Key Specs for Exterior Siding Use
7H pencil hardness • 300°F heat resistance • UV stable, will not chalk or yellow • Recoat in 2-4 hours • Handle after 24 hours, full cure in 7 days • No hardener needed
How to Prep Painted Aluminum Siding First
Painted siding falls under the "clear coating over cured coatings" prep path, not the bare-metal path. Follow these steps before the first coat:
StepWhat to Do
1. CleanWash with KBS Klean diluted 10 parts hot water to 1 part KBS Klean, using a soft, non-abrasive pad.
2. ScuffScuff the cured paint with 600-1200 grit sandpaper to give the clear coat a surface to grip.
3. Clean againRepeat the KBS Klean pass to remove sanding residue.
4. Rinse & dryRinse thoroughly and let the surface dry completely. Do not use solvent wipes or tack cloths; they leave a residue that causes surface tension issues.
Pro Tip: Check for Chalking First
Older camper paint often oxidizes and chalks in the sun. If a white powdery residue comes off on a rag when you wipe the siding, compound or wet-sand that chalky layer off down to solid paint before cleaning and scuffing. Clear coating over chalk traps the powder under the finish and adhesion will fail no matter how well the rest of the prep is done.
Applying It to a Camper or RV
Apply a minimum of two thin, covering coats at about 2 mils dry film thickness each, using a brush, low-nap roller, or spray equipment. Recoat once the previous coat is dry to the touch, usually within 2-4 hours. Ideal application temperature is 50-82°F; avoid rainy, high-heat, or high-humidity conditions.
For coverage planning on a large panel job like camper siding, theoretical coverage is about 400 sq. ft. per gallon at 2 mils, or roughly 200 sq. ft. per gallon for a full two-coat application. Expect somewhat less coverage on rough or heavily textured siding.
Does painted aluminum siding need to be sanded before applying DiamondFinish Clear?
Yes. Scuffing the cured paint with 600-1200 grit sandpaper gives DiamondFinish Clear a surface to mechanically grip. Skipping this step is one of the most common causes of poor adhesion on painted siding.
What if the camper's paint is oxidized or chalky?
Chalky, oxidized paint needs to be addressed before clear coating. Compound or wet-sand the surface first to remove the chalky layer down to solid paint, then clean and scuff as normal. Clear coating directly over chalk traps the powdery residue under the finish and adhesion will fail.
Do I need a primer or adhesion promoter over painted aluminum?
No. DiamondFinish Clear is formulated to apply directly over cured paint without a primer or adhesion promoter. Adhesion promoter is only recommended for bare, unpainted metal.
How many coats of DiamondFinish Clear does painted aluminum siding need?
Apply a minimum of two thin, covering coats at roughly 2 mils dry film thickness each. Recoat once the previous coat is dry to the touch, typically within 2-4 hours.
Will DiamondFinish Clear hold up to sun and temperature swings on an RV?
Yes. DiamondFinish Clear is UV stable and remains permanently flexible, so it resists yellowing, cracking, and peeling as the aluminum siding expands and contracts with temperature changes.
Can I apply DiamondFinish Clear with a roller on a large camper surface?
Yes. A low-nap roller, such as mohair, works well for large panel surfaces. Apply thin coats and avoid overworking the roller in one area so the finish self-levels without roller marks.
Ready to Protect Your Camper's Finish?
Grab DiamondFinish Clear and KBS Klean and get a permanent, UV-stable gloss on your siding.
Shop DiamondFinish Clear Shop KBS Klean
