What is the best way to open my can of DiamondFinish Clear?
Because most of our paint is shipped at some point, there is a chance that the paint in the can might get between the can and the lid — which can make getting the lid off more difficult than it might be with ordinary paint. The main resin in DiamondFinish Clear is an adhesive, so following the steps below will protect both the lid and the seal.
📌 PRO TIP — Use the Right Opener
Always use a paint can opener with a curved or “L”-shaped end. Flat head screwdrivers are not ideal — they tend to warp the lid as you pry, which can compromise the compression seal and make future openings even harder. If there is a plastic ring on the can lid, remove it first.
Follow these steps to open your can of DiamondFinish Clear:
  1. Remove the plastic ring from the can lid if one is present.
  2. Position your paint can opener at one point on the lid and gently lift that section.
  3. Rotate the can 10 degrees, reposition the opener, and lift gently again.
  4. Continue repeating step 3, working all the way around the can.
  5. Go around the can a second time, lifting the lid a little more with each pass.
  6. Repeat until the lid comes off cleanly.
⚠️ IMPORTANT — Do Not Pry From a Single Point
Do not lift the lid from one section only. Doing so will warp the lid and the compression seal, making it difficult — or impossible — to properly reseal the can for future use.
For complete mixing, application, and storage instructions, review the full DiamondFinish Clear Application Directions before you begin your project.
Ready to Get Started?
Order DiamondFinish Clear or review the full application directions to make sure your project goes smoothly from the first coat to the last.
Shop DiamondFinish Clear    View Application Directions
