The paint is peeling off my hood on my car, could I lightly sand it and apply DiamondFinish Clear to these areas?
Yes, DiamondFinish Clear is excellent at arresting peeling paint and small rust areas on a vehicle.
How To Apply
Step 1 — Clean the surface: Remove any loose, lifting clear first. Mix KBS Klean at a ratio of 10 parts hot water to 1 part KBS Klean. Using a green scrub pad (or similar), give the peeling or rusted area a light scrub. Rinse thoroughly and allow to dry completely.
Step 2 — Apply DiamondFinish Clear: Apply DiamondFinish Clear to the affected areas. Always apply thin, covering coats.
Step 3 — Cut, polish & blend: After 24 hours from the final coat, you can cut, polish, and buff those areas to blend seamlessly into the vehicle's existing clear coat.
★ Pro Tip
Always apply thin coats of DiamondFinish Clear. Heavy coats can lead to surface bubbling — multiple thin coats will give you the best adhesion and the cleanest finish.
Review the complete DiamondFinish Clear Application Directions before starting your project.
Ready to stop peeling paint and rust in its tracks?
Pick up everything you need below and get started today.
Shop DiamondFinish Clear Shop KBS Klean Application Directions
