Can tints, pearls, and metal flake be added to DiamondFinish Clear?
Yes. You can add compatible tints, candy concentrates, pearls, or metal flake to liquid DiamondFinish Clear. Because DiamondFinish Clear is a single-component, moisture-cured urethane, every additive must be suitable for urethane coatings and must not introduce water or moisture.
Additives vary in chemistry and concentration. Confirm compatibility with the additive manufacturer, and test the exact combination before applying it to the full project.
Choose a Compatible Additive
  • Use tints, candy concentrates, pearls, or flakes intended for urethane coatings.
  • Do not use water-based colorants or additives that could introduce moisture.
  • Keep powders, mixing tools, and containers completely clean and dry.
  • Confirm that the additive manufacturer approves its use with a single-component, moisture-cured urethane clear coat.
Important: Liquid Product Only
This guidance applies only to liquid DiamondFinish Clear. Do not open, puncture, or attempt to add material to DiamondFinish Clear 1K Aerosol.
Mix a Small Working Batch
Dispense only the amount of DiamondFinish Clear needed for the current application into a separate, clean, dry steel or glass container. Add the selected colorant or effect to that working batch, and stir gently and thoroughly.
There is no universal mixing ratio because pigment strength, flake size, and the desired appearance vary. Follow the additive manufacturer's starting recommendation, record the ratio used, and evaluate a small test panel before mixing additional material.
Never return modified or unused DiamondFinish Clear to the original can. Doing so can introduce moisture or contamination and shorten the life of the remaining product.
Pro Tip
Prepare only what you can apply during the current session. Third-party tints, pearls, and flakes may shorten the working time of DiamondFinish Clear after mixing.
Test Before Coating the Project
Apply the mixture to a properly prepared test panel before coating the finished part. Check the color, effect distribution, clarity, application behavior, and cure. Proceed only after the test produces the appearance and cure you expect.
Follow the complete DiamondFinish Clear application directions for surface preparation, application, recoating, curing, and safety requirements.
Can I add tints, pearls, or metal flake to DiamondFinish Clear?
Yes. Compatible tints, candy concentrates, pearls, and metal flake can be added to liquid DiamondFinish Clear. The additive must be suitable for urethane coatings and must not introduce water or moisture.
What additives are compatible with DiamondFinish Clear?
Use colorants and effects intended for urethane coatings. Confirm compatibility with the additive manufacturer, and test the exact combination before coating the full project.
How much tint, pearl, or metal flake should I add?
There is no universal amount because additive concentrations and desired effects vary. Follow the additive manufacturer's recommendation, mix a small test batch, and record the ratio before preparing more material.
Can additives be mixed into DiamondFinish Clear 1K Aerosol?
No. This guidance applies only to liquid DiamondFinish Clear. Do not open, puncture, or attempt to add material to DiamondFinish Clear 1K Aerosol.
Plan Your DiamondFinish Clear Project
Review the full application directions before mixing or applying DiamondFinish Clear.
Application Directions Shop DiamondFinish Clear
