Can DiamondFinish Clear be applied wet on wet?
No, DiamondFinish Clear should not be applied wet on wet. Apply the next coat when the previous coat is dry to the touch and does not leave a fingerprint. This stage is typically reached within 2 to 4 hours, depending on temperature and humidity.
The key recoat test
The surface should feel firm and dry to the touch. If a light fingertip press leaves a mark, wait longer before applying the next coat.
DiamondFinish Clear Recoat Questions
Can I apply DiamondFinish Clear wet on wet?
No. Wait until the previous coat is dry to the touch and does not leave a fingerprint before applying the next coat. This is beyond the tacky stage and typically takes 2 to 4 hours, depending on temperature and humidity.
When is DiamondFinish Clear ready for another coat?
The coating is ready when it feels dry to the touch and firm, not wet or tacky, and a light fingertip press does not leave a fingerprint.
How long should I wait between coats?
DiamondFinish Clear is typically ready to recoat within 2 to 4 hours. Temperature and humidity affect cure time, so use the fingerprint test to confirm readiness instead of relying only on the clock.
How do I perform the fingerprint test?
Lightly press a fingertip onto an inconspicuous area. Apply the next coat only if the coating feels firm and does not retain a fingerprint. If it feels soft, sticky, or shows an impression, allow it to cure longer.
What should I do if the normal recoat window has passed?
If the previous coat has cured, prepare it before applying another coat. Scuff the surface with 600 to 1200 grit sandpaper, then clean and dry it according to the DiamondFinish Clear application directions.
What should I do if the coating is still tacky?
Wait before recoating. A tacky surface has not reached the proper recoat stage. Check it again later and apply the next coat only when the surface is dry to the touch and does not leave a fingerprint.
Ready to apply DiamondFinish Clear?
Review the product details or open the complete application directions before starting your project.
Shop DiamondFinish Clear   View Application Directions
