How To Attach The Cavity Wand to KBS Cavity Coater Aerosol
In this video, we show you how to properly attach the easy-to-use Cavity Wand to the Cavity Coater Aerosol can.
Keys to Success
  • Shake the Cavity Coater Aerosol can well before use.
  • Gently push the spray tip straight down while giving it a slight twist to attach.
  • Apply when the can and surface are between 65-80°F for ideal spray performance.
Cavity Coater Aerosol is the perfect solution for hard-to-reach areas that are prone to rusting. Cavity Coater is a single step, super-penetrating corrosion inhibiting coating (CIC) designed for long term protection on all metal surfaces. Cavity Coater Aerosol provides a self-healing film which delivers exceptional rust protection on hard-to-reach areas like rocker panels, frame rails, and door cavities.
Ready to Protect Your Hard-to-Reach Cavities?
Get the Cavity Coater Aerosol and Cavity Wand and stop rust before it starts.
Shop Cavity Coater Shop Cavity Wand
