What is the best way to store DiamondFinish Clear after you open the can?
Storing & Handling DiamondFinish Clear
DiamondFinish Clear can easily be stored for at least six months after opening. Do not paint out of the can — do not shake the can. Dispense a working amount of DiamondFinish Clear into a separate container (steel or glass is best) and seal the original can immediately. Keep the can groove free of paint by using a scoop or KBS Paint Spout. Use a plastic zip lock type bag between the lid and the top of the can to stop metal-to-metal contact — DiamondFinish Clear can permanently seal the lid if left in direct contact.
⚠ Do Not Return Unused Paint to the Can
Unused paint should never be put back into the original can — it will shorten shelf life and may cause pressure build-up that pops the lid. If there is any trouble resealing the lid tightly, transfer and store DiamondFinish Clear in a proportionally sized clean glass jar or new paint can. Always store in a cool, dry place.
📝 Pro Tip: Never Mix Old & New Cans
It is best practice never to mix DiamondFinish Clear from a previously opened can with a new can. The older can may contain moisture absorbed from the air, which can significantly reduce the pot life of the fresh material.
Ready to get started with DiamondFinish Clear?
Review the full application directions before your project, or shop DiamondFinish Clear direct.
View Application Directions Shop DiamondFinish Clear
