Rust Converter Versus Removing Rust and Sealing Metal – Which Protects Metal Longest?
KBS Rust Converter applied to a rusty metal surface, showing the rough finish typical of rust converters
Rust converter will stop rust, though the finish quality is rough.
Rust Converter versus Removing Rust and Sealing Metal — Which Protects Metal Longest?
Most everyone knows that once metal starts to rust, it will continue to rust until the metal is completely eaten away. So it's important to stop rust as soon as it's discovered. Here we'll discuss two methods used to stop rust. The first is using rust converter to convert the rust into an inert primed layer that can stand alone or be painted over. The second is to completely remove the rust from the metal, then apply a rust preventive paint or coating to protect it. Both techniques stop rust and seal the metal from moisture and oxygen to keep it from rusting again. However, results vary in how long the metal stays rust-free and in the quality and appearance of the finish.
Quick Answer
Removing rust and sealing the metal with a rust preventive coating lasts longer and looks better than rust converter, but takes more time and labor. Rust converter is faster and cheaper up front but needs to be redone sooner.
Method — Using Rust Converter
Rust converter, also known as rust reformer, is a chemical solution or primer applied directly to a metal surface to convert iron oxide (rust) into a protective chemical barrier that resists moisture and further corrosion. Rust converter is made from phosphoric acid, tannic acid, or a blend of both. Phosphoric acid rust converter turns iron oxide into a ferric phosphate inert layer, and it can be used on metal parts exposed to exterior weather conditions if topcoated with a quality paint or coating. Tannic acid produces a protective bluish-black ferric tannate inert primer layer, which can stand alone against exterior weather conditions or be painted over for better appearance — it acts as an excellent primer for both oil and epoxy-based paints. Rust converter works on any rusty iron or steel object, but it will not work on aluminum, copper, stainless steel, or galvanized metal.
Benefits of Using Rust Converter
With rust converter, it's necessary to first remove any loose or flaking rust with a stiff bristle brush, wire wheel, or sandpaper, to provide a stable surface. It's important not to remove all the rust, since that would defeat the purpose of rust converter, which chemically bonds to rust and seals it in. Applying rust converter is a simple, quick procedure compared to eliminating rust and sealing the metal with a rust preventive coating — especially advantageous when project time is limited or the object is large and thorough rust removal would be highly labor-intensive.
Drawbacks of Using Rust Converter
When done properly, eliminating rust and sealing the metal with a rust preventive paint or coating provides a longer-lasting solution than rust converter. While time and labor are reduced up front with rust converter, the procedure has to be repeated before too long. In some cases, a good rust elimination and metal seal job protects against future rust four to five times longer than rust converter.
Finish quality can also be compromised when using rust converter. Eliminating rust typically provides a smoother surface for rust preventive paints and coatings, allowing for a smoother, better-looking final finish. Rust converter is also designed to bond to rust, so it won't work on non-rusty surfaces or surfaces with a mix of rusty and non-rusty areas.
KBS Rust Converter
KBS Coatings offers Rust Converter that easily converts a rusty surface into a black, inert primed surface ready for paint and compatible with most topcoats. It's offered in aerosol form for easy application and dries fast.
KBS Rust Converter aerosol can for converting rust to an inert primed surface
Method — Remove Rust and Seal the Metal with a Paint or Coating
Rust fully removed and metal sealed with a rust preventive coating for a smooth finish
Rust removed, and metal sealed with a coating.
For stopping rust, the best and longest-lasting result comes from eliminating rust, using a primer to seal the metal from moisture and oxygen, then applying a topcoat of paint or other coating. It's important that the rust is thoroughly removed and that a strong-bonding, durable paint or coating is applied.
Rust Removal
Rust can be removed with chemicals, solvents, and abrasives. As with rust converter, the first step is to remove loose flaking rust with a stiff bristled brush or sandpaper. Below are common rust removal methods.
MethodHow It Works
White vinegarDissolves rust when the metal is soaked for a few hours, leaving a "rusty paste" that can be scrubbed off. For large objects, pour vinegar on, let it sit, then scrub.
Oxalic acidAn odorless white crystalline acid mixed with water into a colorless solution. Requires gloves, a mask, and safety goggles. Soak the object; results appear within 20 minutes, up to 24 hours for heavy rust.
Petroleum-based solventsProducts like WD-40 remove rust and are less corrosive or toxic than acids. Allow up to 24 hours for full effect.
Water-based rust removersAcid-free removers lift rust through chelation, bonding to rust and drawing it away from the metal. Immerse or spray, then leave 30 minutes for light rust or up to overnight for heavy rust.
Abrasives are a mechanical form of rust removal — sanding by hand or with power tools like an angle grinder, sander, or a drill fitted with a surface finishing disc, cup brush, or wire wheel. Sandblasting is also a popular, easy way to remove rust, and it gives the metal a surface texture that helps paint bond firmly.
Painting/Coating
After rust is removed, the metal needs to be sealed to prevent it from rusting again. A primer is applied and usually topcoated with a paint or coating. Some paints include a primer in their formulation.
Primer — While a metal paint primer isn't always required, it's always recommended, especially if the metal will contact moisture. Depending on the topcoat, the metal may or may not require primer to seal it first. The most popular primer types are self-etching primer and epoxy primer.
Self-etching primer provides a strong bond to the surface and seals metal from air and moisture. It uses an acid to micro-etch the metal for a slightly rough "anchor pattern" surface profile (similar to sandblasting) that gives the primer increased grip and provides a strong base for the topcoat. Some self-etching primers deposit a layer of zinc phosphate for increased adhesion, and they cure quickly, which helps reduce project time.
Epoxy primer provides excellent adhesion when priming metal, but because it doesn't etch the metal like self-etching primer, the proper surface profile must be created manually by sanding with 80 to 180-grit sandpaper or by sandblasting. Epoxy primers also take longer to cure than self-etching primer.
Paint or Coating — When topcoating a primer, the topcoat must be compatible with the primer. No paint will bond to unprepared epoxy paint — epoxy-painted surfaces must be abraded before they'll accept new paint. Sanding old epoxy with 120 to 220-grit sandpaper promotes adhesion; once abraded, any type of paint will bond to it.
Benefits of Removing Rust and Sealing the Metal
As long as the job is done effectively, the best and longest-lasting result for stopping rust comes from eliminating the rust and sealing the metal from moisture and oxygen. Finish quality is also better than with rust converter.
Drawbacks of Removing Rust and Sealing the Metal
The main drawback of removing rust and sealing the metal is that the procedure is more labor-intensive than using rust converter, and material costs are usually higher. In this case, though, you get what you pay for.
KBS Coatings 3-Step System
KBS Coatings offers the user-friendly 3-Step System to stop rust. It performs all the functions necessary to properly remove rust and seal the metal for the best long-term protection.
Step 1 — KBS Klean
After removing any loose or flaking rust with a stiff bristled brush or sandpaper, this biodegradable cleaner removes dirt, oil, grease, and other contaminants — scrub in with a brush or scouring pad.
Step 2 — RustBlast
A water-based, biodegradable solution that dissolves and neutralizes rust while acting as a pre-paint primer, etching the metal for solid paint adhesion. Spray on, keep wet for about 30 minutes, then rinse off with water.
Step 3 — RustSeal
A single-part coating that seals metal from moisture and oxygen. Brush, spray, or roll it on to form a tough, ceramic-like coating that's hard to chip or scratch and won't crack or peel.
More information on the KBS 3-Step System is available in the System Sampler Kit.
KBS System Sampler Kit, a complete rust prevention paint kit covering 12.5 square feet
So, What's Best for Stopping Rust?
Ultimately, it comes down to your goals for protection longevity and visual appeal. KBS Rust Converter does a good job of stopping rust and is a relatively quick process compared to eliminating rust and sealing the metal with a paint or coating. However, it won't protect metal as long, and the finish quality won't be as smooth and attractive.
Is rust converter or removing rust and sealing the metal better?
Removing rust and sealing the metal with a rust preventive coating provides longer-lasting protection and a smoother finish than rust converter. In some cases, a proper rust removal and seal job protects metal four to five times longer than rust converter. Rust converter is faster and less labor-intensive, but it needs to be reapplied sooner.
Does rust converter work on all metals?
No. Rust converter works on any rusty iron or steel object, but it will not work on aluminum, copper, stainless steel, or galvanized metal, and it won't work on surfaces without rust to bond to.
Do I need to remove all the rust before using rust converter?
No. Remove any loose or flaking rust with a stiff brush, wire wheel, or sandpaper first, but leave the remaining adhered rust in place. Rust converter chemically bonds to rust to seal it, so removing all of it would defeat the purpose.
What is the KBS 3-Step System?
The KBS 3-Step System removes and seals rust for long-term protection. Step 1 is KBS Klean, a biodegradable cleaner and degreaser. Step 2 is RustBlast, a water-based rust remover and metal etch. Step 3 is RustSeal, a single-part coating that seals metal from moisture and oxygen with a tough, ceramic-like finish.
Ready to Stop Rust for Good?
Whether you choose Rust Converter or the full 3-Step System, KBS Coatings ships factory direct the same day.
Shop the 3-Step System Shop Rust Converter
