VIDEO: Stacey David from Gearz Shares How To Seal A Tank With The KBS Tank Sealer System
▶ Featured Video — Gearz: How To Seal A Gas Tank
Stacey David from Gearz walks through the complete process of prepping and sealing a fuel tank using the KBS Tank Sealer System — a one-part, ready-to-use sealer specifically formulated to stop rust and corrosion permanently.
About KBS Tank Sealer
KBS Tank Sealer is a superior, one-part, ready-to-use fuel tank sealer impervious to all modern fuels, alcohol additives, and most solvents. Works on:
•  Gasoline and diesel fuel tanks
•  Biodiesel tanks
•  Oil and utility tanks
•  Non-potable water tanks
The KBS Tank Sealer System — Everything Included
The KBS Tank Sealer System is an all-inclusive kit that takes the guesswork out of sealing your tank. Everything you need comes in one box — just choose the kit sized for your tank. KBS offers multiple kit sizes to handle tanks large and small.
What makes the KBS Tank Sealer System different from a single-product tank sealer?
It is a matched 3-step kit — KBS Klean degreases, RustBlast preps with a zinc phosphate bonding profile, and Gold Standard Tank Sealer forms the permanent seal. That prep step gives Tank Sealer a better bonding surface than sealer alone.
What types of tanks can I use it on?
Metal, aluminum, and fiberglass tanks from 1 to 100 gallons — automotive and motorcycle fuel tanks, diesel tanks, oil and hydraulic tanks, and non-potable water tanks.
How long does Gold Standard Tank Sealer need to cure before adding fuel?
A full 96 hours (4 days). Don't rush the cure with heat guns or direct sunlight.
Ready to seal your tank?
Shop Tank Sealer Kits    View Tank Sealer
