VIDEO: How To Use KBS Paint Mixing Cups
Mixing components in the correct ratio can be tricky. There's often a lot of guesswork involved in measuring out the proper amount of paint, hardener, and thinner, as well as other mixtures. KBS Paint Mixing Cups take out the guesswork and let you mix with confidence, precisely measuring the amount of each component needed to reach the desired ratio.
What Ratios Can the Paint Mixing Cup Handle?
KBS Paint Mixing Cup at a Glance
Ratio range — measures mix ratios from 1:1 up to 7:1.
Where the ratio comes from — check the application instructions for the paint and hardener (or cleaner) you're using to find the correct ratio, then use the cup to measure it out.
Works for more than paint — also useful for mixing KBS Klean with water at the correct dilution.
Watch the Video Walkthrough
The video above shows how the KBS Paint Mixing Cup is used to mix paint, hardener, and thinner, as well as other mixtures like KBS Klean and water.
Ready to Mix with Confidence?
Pick up a KBS Paint Mixing Cup and take the guesswork out of your next mix.
Shop KBS Paint Mixing Cup Shop KBS Klean
What mix ratios can a KBS Paint Mixing Cup handle?
KBS Paint Mixing Cups can measure ratios from 1:1 up to 7:1, covering the range used for paint, hardener, and thinner combinations as well as cleaner-and-water mixtures.
How do I know what mix ratio to use?
The mix ratio comes from the product's own application instructions, not the cup. The Paint Mixing Cup just makes it easy to measure out that ratio accurately once you know it.
Can KBS Paint Mixing Cups be used for products other than paint?
Yes. They work for any two-part or diluted mixture, including KBS Klean diluted with water, not just paint, hardener, and thinner combinations.
Ready to get mixing?
Grab a KBS Paint Mixing Cup and mix with confidence. Ships fast from Valparaiso, IN.
Shop KBS Paint Mixing Cup Shop KBS Klean Contact KBS Coatings
