Customer Project Showcase
Applicator Rikk C. shares how he restored a jet ski by mixing candy pigment and metal flake directly into DiamondFinish Clear, taking advantage of its Direct To Metal adhesion to build a custom candy finish without a separate base coat.
Here are some pictures that I took. I'll explain what I did to get the result that I wanted.
I ended up having to make my own red base coat because the aluminum had been media blasted and had a really grey appearance, and the customer didn't want me to go through the extra step of prepping the aluminum for use as my base coat for candy.
I had some really coarse silver left over from the base on the ski, so that's where I started. After playing around at the mixing bank, I added some base coat pigments and a little binder for color, plus a couple of effect pigments, and I ended up with the color the customer wanted.
Mixing Pigment Directly Into DiamondFinish Clear
The next step was to mix the pigments into DiamondFinish Clear, using about 20-30% by volume. It wasn't enough to be opaque, but with 2 coats it covered well.
The reason for mixing in the clear was solely for DTM adhesion, and I wanted to see how far I could go with introducing a large amount of pigments into DiamondFinish Clear.
I followed up with a urethane-grade red candy concentrate that I added to a fresh batch of DiamondFinish Clear, and that finished it off.
Jet ski panel with red candy pigment mixed into DiamondFinish Clear
Restoring the Black Panels to Gloss
The black that you see was rattle-can satin black the customer had already applied. It was fully cured. The customer said he wanted this section gloss black, so I shot DiamondFinish Clear right over the top.
Jet ski satin black panel restored to gloss black with DiamondFinish Clear
Adding Flake Over the Black Sections
At this point I was done, until the customer wanted me to shoot some .008 OSF Ghost Fire flake over the black sections. So, two more coats and it was buried, and now I was done.
.008 OSF Ghost Fire metal flake shot over black panels and buried under DiamondFinish Clear
Finished jet ski panel showing candy red and flake black sections coated with DiamondFinish Clear
Final Results
It looks great! I'm happy with the result, and the customer is more than happy.
Completed jet ski restoration with candy pigment and flake finish sealed in DiamondFinish Clear
In the Applicator's Words
"All in all, I have to say I really like DiamondFinish Clear. It couldn't be easier to shoot, and I LOVE the high solids!"
"I have been shooting flake for years, and DiamondFinish Clear is exactly what the doctor ordered! I'd been looking forward to trying it out for a couple months, and I'm glad I did." — Rikk C.
Full-length view of the restored jet ski with candy pigment and flake DiamondFinish Clear finish
Can pigment or candy concentrate be mixed directly into DiamondFinish Clear?
Yes. Base coat pigments, effect pigments, and urethane-grade candy concentrates can be mixed into DiamondFinish Clear at the mixing bank. Using roughly 20-30% pigment by volume produces a tinted, translucent color coat rather than a fully opaque one, so multiple coats are used to build coverage and depth.
Why mix pigment into the clear coat instead of using a separate base coat?
Mixing pigment into DiamondFinish Clear takes advantage of its Direct To Metal (DTM) adhesion, so the tinted coat bonds straight to bare or media-blasted metal without a separate base coat or adhesion promoter.
Can DiamondFinish Clear be applied over cured rattle-can or aerosol paint?
Yes. DiamondFinish Clear can be applied over fully cured paint, including aerosol or rattle-can finishes, to add gloss, depth, and protection without disturbing the existing color coat.
Can metal flake be added into a DiamondFinish Clear topcoat?
Yes. Metal flake can be shot into or over a DiamondFinish Clear coat and then buried under additional coats of clear for a smooth, durable finish that seals and protects the flake.
Ready to Try DiamondFinish Clear on Your Next Project?
High-solids, Direct To Metal clear coat that bonds straight to bare metal or over cured paint. No hardener needed. Order direct and we ship same day.
Shop DiamondFinish Clear Ask a Question
