Can I clear coat wood with DiamondFinish Clear?
Yes — DiamondFinish Clear works beautifully on wood surfaces, both sealed and raw. The preparation steps differ slightly depending on the condition of the wood, so follow the appropriate guide below.
Applying to Sealed Wood
If the wood is already sealed, lightly scuff sand any imperfections to give the surface tooth, then wipe it down with a mild solution of KBS Klean (1 Part KBS Klean to 25 Parts Water) to remove any contaminants. Once clean and dry, proceed with nice, thin coats of DiamondFinish Clear.
Applying to Raw / Unsealed Wood
Raw wood surfaces should be smooth and dry with a low moisture content before you begin. Follow these steps:
  1. Thin the first coat of DiamondFinish Clear 30–50% with KBS #1 Thinner and apply a single covering coat to seal the wood.
  2. Allow to cure for 24 hours. DiamondFinish Clear will tend to raise the wood grain on the first coat — this is normal.
  3. Sand the surface smooth with a fine-grit sandpaper (280–320 grit).
  4. Apply at least one additional full coat for general applications.
⚠ Marine & Industrial Applications
For marine or industrial use, apply a minimum of three full coats of DiamondFinish Clear over raw wood to ensure adequate film build and long-term protection.
💡 Pro Tip — Thinning for Wood Penetration
Thinning that first coat with KBS #1 Thinner allows DiamondFinish Clear to penetrate deeper into the wood fibers, creating a stronger bond and a better foundation for subsequent coats.
📋 Review the Full Directions Before You Begin
For complete application instructions, dry times, thinning ratios, and recoat windows, review the Complete DiamondFinish Clear Directions before starting your project.
Ready to Get Started?
Pick up everything you need to protect and beautify your wood project with a crystal-clear, durable finish.
Shop DiamondFinish Clear Shop KBS #1 Thinner Shop KBS Klean
