Can I use the KBS Tank Sealer System on a bio-diesel fuel tank?
Yes — the KBS Tank Sealer System is designed to prep and seal bio-diesel tanks. Tank Sealer is completely impervious to bio-diesel, making it the ideal solution for sealing up a bio-diesel tank.
Fuel Compatibility
Tank Sealer is impervious to both standard diesel and bio-diesel fuel blends, so the same 3-step process applies whether you are sealing a diesel or bio-diesel tank.
Review the complete Tank Sealer Application Directions before beginning your project.
Ready to Seal Your Bio-Diesel Tank?
The KBS Tank Sealer System permanently seals fuel tanks against rust, leaks, and modern ethanol and bio-diesel blends.
Shop the Tank Sealer SystemView Application Directions
