Can the Tank Sealer System be used on oil tanks?
Yes, the KBS Tank Sealer System is used all the time to prep and seal up oil tanks.
Prep Is the Key With Oil Tanks
Be sure you prep the surface well — any oil residue that is not cleaned from the inside of the tank could cause long-term performance issues with the sealer.
Please read the complete Tank Sealer Application Directions before you begin your project.
Ready to Seal Your Oil Tank?
The KBS Tank Sealer System prepares and permanently seals oil tanks against rust and leaks.
Shop the Tank Sealer SystemView Application Directions
