Can I just use the Tank Sealer and skip the KBS Klean and RustBlast?
Tank Sealer was designed to be a long-term rust prevention and sealer solution, and the KBS prep process was built specifically to complement and enhance its performance. It is possible to apply Tank Sealer without using KBS Klean and RustBlast, but you are risking poor adhesion and premature failure.
Why Prep Matters
KBS Klean cleans the surface thoroughly, and RustBlast etches the metal to leave an anchor pattern — together they give Tank Sealer incredible, lasting adhesion.
As with any coatings job, prep is roughly 90% of the job, and the same holds true with the KBS Tank Sealer System. If you want the longest-lasting results, always complete all three steps rather than skipping ahead.
Review the complete Tank Sealer Application Directions before starting your project.
Ready to Seal Your Tank Right?
Get the complete KBS Tank Sealer System — clean, etch, and seal for a permanent fix.
Shop the Tank Sealer SystemView Application Directions
