Can I reuse the KBS Klean solution when cleaning the tank?
Yes, drain the used KBS Klean solution into a bucket and keep it until you can inspect the inside of the tank to verify it has been cleaned well. You can filter the solution as it drains into the bucket to remove rust and debris.
How Many Times Can You Reuse It?
You can always reuse the KBS Klean solution if the inside of the tank needs additional cleaning. Some customers have cleaned their tank up to ten times with the same solution — it all depends on how dirty and contaminated the inside of your tank is when you start.
Pro Tip
Placing some nuts and bolts or a loose chain inside the tank, along with frequent shaking and rotation with the KBS Klean solution, will help knock away loose rust and contaminants.
Please review the complete Tank Sealer Application Directions before beginning your project.
Ready to Clean and Seal Your Tank?
KBS Klean is the first step in the complete Tank Sealer System — clean, etch, and seal for lasting protection.
Shop KBS KleanView Application Directions
