Is BlackTop urethane based?
Yes, BlackTop (non-aerosol) is a moisture cured urethane, an advanced coatings technology that delivers an exceptional combination of properties in a single coating.
Pro Tip: Why Moisture Cured Urethane?
The formula gives BlackTop three standout characteristics: extreme durability (resists abrasion, corrosion, and chemical exposure), flexibility (moves with the surface without cracking or peeling), and excellent adhesion (bonds strongly to properly prepared surfaces).
Before you begin, review the complete BlackTop application instructions for full prep, coat, and cure guidance.
Ready to Shop BlackTop?
Get the full BlackTop directions and shop BlackTop, a moisture cured urethane built for durability, flexibility, and long-lasting adhesion.
BlackTop DirectionsShop BlackTop
