The best brush for applying BlackTop is a poly bristle brush, specifically designed to lay coating on smoothly without dragging or leaving heavy bristle lines.
Pro Tip: Brush It On and Move On Do not overwork the brush. Brush an area and move on immediately. Do not go back over the same spot repeatedly. Overbrushing forces the solvents out of the coating before they can do their job, causing BlackTop to cure too quickly and leaving visible brush marks that won't flow out as designed. |
Before you begin, review the complete BlackTop application instructions for full prep, brushing technique, and cure guidance.
Ready to Apply BlackTop? Get the full BlackTop directions, shop the right poly bristle brush, and pick up BlackTop: everything you need for a smooth, professional brush finish. BlackTop DirectionsShop Poly Paint BrushShop BlackTop |
