Can BlackTop be applied over epoxy primer or polyester filler primer?
Yes, BlackTop adheres well to fully cured epoxy primers, DTM primers, and body fillers. As long as the surface is fully cured, BlackTop will bond to all three without issue.
Pro Tip: Got a Glossy Surface?
If the surface to be coated has a glossy or shiny sheen, lightly scuff it with 320 grit sandpaper before applying BlackTop. This gives the coating more surface area to grip, resulting in stronger, longer-lasting adhesion.
Before you begin, review the complete BlackTop application instructions for full prep, coat, and cure guidance.
Ready to Apply BlackTop?
Get the full BlackTop directions and shop BlackTop: a durable, UV stable finish that bonds directly to epoxy primer, DTM primer, and body filler.
BlackTop DirectionsShop BlackTop
