Can I brush on the BlackTop paint or does it have to be sprayed?
Yes, BlackTop can absolutely be brushed on. It is specifically formulated so that when brushed, it flows out to a finish that looks like it has been sprayed.
Pro Tip: Brush It On and Move On
The key to a great brush finish is to not overwork the brush. Brush an area and move on immediately. Do not go back over the same area repeatedly. Overbrushing forces the solvents out of the coating before they can do their job, causing BlackTop to cure too quickly and leaving visible brush marks that won't flow out as designed.
Before you begin, review the complete BlackTop application instructions for full prep, brushing technique, and cure guidance.
Ready to Apply BlackTop?
Get the full BlackTop directions and shop BlackTop, a UV stable, self-leveling coating that brushes on like a spray finish.
BlackTop DirectionsShop BlackTop
