Can BlackTop Aerosol be applied directly to aluminum?
Yes, BlackTop Aerosol adheres very well to bare aluminum surfaces. The prep process is straightforward: clean the bare aluminum thoroughly with KBS Klean, rinse, and allow to dry completely. Then apply BlackTop Aerosol in thin, covering coats.
Pro Tip
A clean, residue-free surface is the key to strong adhesion on aluminum. KBS Klean leaves no residue behind. Always let the surface dry fully before applying BlackTop Aerosol for the best bond.
Before you begin, review the complete BlackTop application instructions for full prep, coat, and cure guidance.
Ready to Coat Your Aluminum?
Get the full BlackTop Aerosol directions and shop BlackTop and KBS Klean: everything you need for a clean, durable finish on bare aluminum.
BlackTop DirectionsShop BlackTop
