Induction Time for KBS MAXX and KBS MAXX Clear
For KBS MAXX and KBS MAXX Clear, there is no induction time, which means you can start applying as soon as the Base Component and Activator have been mixed together well. Once the two parts are mixed, the paint is activated and should be applied immediately and within 30 minutes for best results.
Pro Tip: Mixing Ratio
After the KBS MAXX Base (color) has been mixed well and smooth in consistency, carefully measure 3 parts mixed Base to 1 part MAXX Activator in a mixing cup/container. Mix thoroughly. Use of a mechanical mixer (KBS Hurricane Paint Mixer or similar mixing blade attached to a variable speed drill) is highly recommended.
Carefully read and follow the application directions for KBS MAXX or KBS MAXX Clear before you begin.
Ready to Mix and Apply?
Shop KBS MAXX, KBS MAXX Clear, and the Hurricane Paint Mixer for a proper mix every time.
Shop KBS MAXXShop KBS MAXX ClearShop Hurricane Paint Mixer
