Can Metallic Colors of KBS MAXX Be Brushed?
Spraying KBS MAXX produces the best metallic finish — the spray process allows the metallic pigments to float to the surface, creating that distinctive metallic sparkle. That said, spraying isn't always an option, and we get that.
Pro Tip: The Two-Pass Brushing Technique
For a great metallic finish when brushing KBS MAXX, use this two-pass technique:
  1. Brush out the KBS MAXX and let the coat cure for a few minutes.
  2. Lightly brush the surface again in one direction only. This second pass floats the metallic pigments to the surface, giving you a beautiful metallic sparkle finish.
As with all painting techniques, practice makes perfect.
Before you begin, review the complete KBS MAXX Application Directions for full prep, thinning, and coat guidance.
Ready to Apply KBS MAXX?
Get the full KBS MAXX directions and shop KBS MAXX — a UV stable 2K single stage topcoat available in stunning metallic finishes.
KBS MAXX DirectionsShop KBS MAXX
