KBS MAXX On Engine Block
KBS MAXX can be used on an engine block that operates below 350F, which covers most water-cooled engines, after prepping with KBS Klean.
KBS MAXX Clear on Wood
KBS MAXX Clear works well on raw, dried wood; thin the first coat 30-50% with KBS #1 Thinner, sand after grain raise, then apply at least one more full coat (three or more for marine/industrial use).
RustBlast Before KBS MAXX Clear
Skip RustBlast before KBS MAXX Clear when trying to preserve a bare metal look, since RustBlast's zinc phosphate residue can cloud the clear coat and slightly alter the metal's appearance.
Induction Time for KBS MAXX and KBS MAXX Clear
KBS MAXX and KBS MAXX Clear have no induction time; apply immediately after mixing Base and Activator, ideally within 30 minutes.
Can Metallic Colors of KBS MAXX Be Brushed?
An extremely popular brushing technique for brushing metallic coatings is to brush out the KBS MAXX, let the coat cure for a few minutes, then lightly brush the surface again in one direction which will help float the metallic pigments to the surface giving you a nice metallic sparkle finish. +Read More.
Is KBS MAXX resistant to scratching and chipping?
KBS MAXX is very durable and extremely resistant to scratching and chipping. +Read More.
What is the best way to mix KBS MAXX?
KBS MAXX is a high solids coating which gives it incredible performance and means that mixing well is key to long term durability and appearance. +Read More.
Can you mix colors of KBS MAXX together to create a custom color?
KBS MAXX colors can be mixed together to create a custom color of KBS MAXX when that is desired. +Read More.
