Can you mix colors of KBS MAXX together to create a custom color?
Yes — you can mix KBS MAXX colors together to create a custom color. You can also add KBS MAXX Silver Metallic into any color to give it a stunning metallic effect.
Pro Tip: Always Follow This Mixing Order
Mixing order matters with a 2K coating. Always follow these steps:
  1. Mix the KBS MAXX Base Components together first — blend your custom color combination until fully uniform.
  2. Then add the KBS MAXX Activator — never add the activator before the base components are fully blended.
Before you begin, review the complete KBS MAXX Application Directions for full mixing ratios, pot life, and coat guidance.
Ready to Create Your Custom Color?
Get the full KBS MAXX directions and shop KBS MAXX and KBS MAXX Activator — everything you need to mix your perfect custom color and get it on the surface.
KBS MAXX DirectionsShop KBS MAXX ActivatorShop KBS MAXX
