How can Motor Coater be applied to an oil pan? Prep required?
Yes, Motor Coater is ideal for coating an oil pan. The application process is the same as coating an engine: thorough surface prep is the key to a long-lasting, professional finish.
Pro Tip
Before applying Motor Coater, prime your prepped oil pan with RustSeal. Oil pans are constantly exposed to moisture and road debris. RustSeal permanently stops rust from forming under your finish coat.
Before you begin, review the complete Motor Coater application instructions for full prep, priming, and coat guidance.
Ready to Coat Your Oil Pan?
Get the full Motor Coater directions and shop Motor Coater and RustSeal: everything you need for a rust-proof, show-quality oil pan finish.
Motor Coater DirectionsShop Motor Coater
