Can I Make Motor Coater An Aerosol?
Motor Coater Engine Paint is formulated to flow out to a beautiful, rich, durable finish when brushed on. Many colors are also available in a convenient aerosol can for certain applications. For colors not available as an aerosol, you can easily convert Motor Coater to a spray application using the Preval Sprayer Kit. Simply thin Motor Coater 30 to 40% with KBS #1 Thinner or Xylene, load the Preval Sprayer Kit, and spray to produce an incredible finish.
Pro Tip
When spraying with the Preval Sprayer Kit, thin Motor Coater 30 to 40% with KBS #1 Thinner or Xylene for best atomization and finish quality.
Before you begin, review the complete Motor Coater application instructions for prep, thinning ratios, and coat guidance.
Ready to Paint Your Engine?
Review the full Motor Coater directions, then shop Motor Coater and everything you need to get a professional finish.
Motor Coater DirectionsShop Motor Coater
