What is the maximum temperature Motor Coater can handle?
Motor Coater is rated to 450°F and is guaranteed not to burn off, more than enough for water cooled engines, oil pans, transmissions, brake calipers, and similar applications.
Pro Tip: Need Higher Heat Resistance?
If your application reaches temperatures of 1200°F or higher, such as exhaust headers, manifolds, or other extreme heat surfaces, XTC Xtreme Temperature Coating is the right product for the job. XTC is specifically engineered for extreme high-heat applications where Motor Coater is not designed to be used.
Ready to Coat Your Engine?
Get the full Motor Coater directions and shop the right coating for your application: Motor Coater for engines and components up to 450°F, or XTC for extreme heat surfaces up to 1200°F.
Motor Coater DirectionsShop Motor CoaterShop XTC Coatings
