Spraying Motor Coater produces the best metallic finish: the spray process allows the metallic pigments to float to the surface, creating that distinctive metallic sparkle. That said, spraying isn't always an option, and we get that.
Pro Tip: The Two-Pass Brushing Technique For a great metallic finish when brushing Motor Coater, use this two-pass technique:
As with all painting techniques, practice makes perfect. |
Before you begin, review the complete Motor Coater application instructions for prep, thinning, and coat guidance.
Ready to Paint Your Engine? Get the full Motor Coater directions, then shop Motor Coater in the color and format that works best for your project. Motor Coater DirectionsShop Motor Coater |
