To apply Motor Coater with a spray gun, do I reduce, how much, and with what?
When spraying Motor Coater, the following spray pressures are recommended: Siphon / Pot guns: 35 to 45 psi (250 to 330 kPa). Gravity / Top container guns: 25 to 35 psi (170 to 250 kPa). Thinning of 5 to 10% is normally adequate. Use KBS #1 Thinner or Xylene only: both are slower evaporating solvents specifically designed to work with Motor Coater for a smooth, professional finish.
Pro Tip
Only use KBS #1 Thinner or Xylene to thin Motor Coater. Their slower evaporation rate allows the coating to flow and level properly. Fast evaporating solvents can cause dry spray and poor adhesion.
Before you begin, review the complete Motor Coater application instructions for full prep, thinning, and spray guidance.
Ready to Paint Your Engine?
Get the full Motor Coater directions and shop Motor Coater and KBS #1 Thinner to get everything you need for a professional finish.
Motor Coater DirectionsShop Motor Coater
