RustSeal Forum
Get Answers about RustSeal. RustSeal is a superior one part (1K), ready-to-use, high-solids content, rust preventive coating, that is actually hardened by exposure to moisture. It is impervious to road salts and most every chemical. RustSeal flows out to a beautiful, rock-hard, tough ceramic-like coating that is tough to chip or scratch, and will not crack or peel.
Heat Limits of RustSeal
Wondering how much heat Rust Seal will tolerate. Am re-doing re-packable motorcycle mufflers and thinking about coating the internal baffle with Rust Seal. Otherwise, I can use the Xtreme Hi-Temp coat...
Mar 11, 2025
by KBS Coatings Support Agent
1
RustSeal Stored In Garage
Where should I store RustSeal before I used it and then after it has been used with some left? Is my garage OK? [RustSeal](https://www.kbs-coatings.com/rustseal) should always be stored in a cool, dry...
Mar 10, 2025
1
Thinning Rust Seal more than 10%?
I'm using your galvanized RustSeal. It's thick and I know in the directions it says you can thin up to 10%. What will happen if I thin it more than 10%?
Mar 07, 2025
1
RustSeal Over Eastwood Afterblast
i just sandblasted the undercarriage of my 67 fastback. after blasting i used eastwoods "afterblast" product to keep the metal from rusting. can rust seal be applied on the metal after the afterblast ...
Mar 06, 2025
1
Bake RustSeal To Speed Cure
Can I bake RustSeal to speed up the cure time? I would like to put it in the booth and bake it. [RustSeal](https://www.kbs-coatings.com/rustseal) is a moisture cured urethane (catalyzed by moisture in...
Nov 13 (7 months ago)
1
Which Rust Protection Kit for 1992 Extended Cab Chevy?
I’m just wondering what kit I should buy. I have a 1992 extended cab Chevy. Should I buy the hundred square feet to prep and paint the frame? Yes, for the extended cab truck frame, the [Large Frame Co...
Jul 25 (11 months ago)
1
