Bake RustSeal To Speed Cure
Nov 13 (7 months ago)
Guest wrote
Can I bake RustSeal to speed up the cure time? I would like to put it in the booth and bake it.
1 Answer
Avatar image
RustSeal is a moisture cured urethane (catalyzed by moisture in the air), so dry heat from baking can actually slow the cure of RustSeal.
You can speed the cure of RustSeal with air flow and humidity (humidifier, wet towels on the ground, etc.).
Always allow RustSeal to cure normally until it it is dry-to-touch and does not leave a fingerprint, and then add the air flow and humidity.
RustSeal TDS and Detailed Application Directions: https://www.kbs-coatings.com/rustseal-directions
RustSeal Link -> https://www.kbs-coatings.com/rustseal
Please reach out if you have any additional questions.
