Heat Limits of RustSeal
Mar 11, 2025
Guest wrote
Wondering how much heat Rust Seal will tolerate. Am re-doing re-packable motorcycle mufflers and thinking about coating the internal baffle with Rust Seal. Otherwise, I can use the Xtreme Hi-Temp coatings that I have. Just thought that Rust Seal due to its consistency, might be a little more tenacious if it would tolerate say, 400º
Thank you!
1 Answer
Avatar image
Mar 11, 2025
RustSeal is high temperature paint which is good to 600F continuous surface temperature, so 400F is no problem at all.
Please be sure you read and follow the complete application directions for RustSeal which can be found here -> https://www.kbs-coatings.com/rustseal-directions
Please reach back out if you have additional questions.
