RustSeal Over Eastwood Afterblast
Mar 06, 2025
Guest wrote
i just sandblasted the undercarriage of my 67 fastback. after blasting i used eastwoods "afterblast" product to keep the metal from rusting. can rust seal be applied on the metal after the afterblast from eastwood which i believe is just a phosphoric coating?
1 Answer
Avatar image
Mar 06, 2025
We have never tested afterblast, but it seems like it should not be a problem as long as you take a green pad and slightly rub the surface to remove possible excess zinc phosphate. The proceed to applying RustSeal.
Your success is key, so be sure to read the RustSeal TDS and Detailed Application Directions 👉 https://www.kbs-coatings.com/rustseal-directions
If you have any additional questions, do not hesitate to reach back out.
