Thinning Rust Seal more than 10%?
Mar 07, 2025
Guest wrote
I'm using your galvanized RustSeal. It's thick and I know in the directions it says you can thin up to 10%. What will happen if I thin it more than 10%?
1 Answer
Avatar image
Mar 07, 2025
Yes, you can thin/reduce RustSeal more than 10% with KBS #1 Thinner or Xylene if that is desired.
Note: When reducing more than 10%, RustSeal could take longer to cure and more than 2 coats might be needed to get at least 5 mils of Dry Film Thickness which is desired for the ultimate rust protection.
Please review the complete RustSeal Application Directions before you begin your project and do not hesitate to Reach Out if you have any questions.
