Is there a difference between xylene and a product labeled xylene replacement?
Products labeled xylene replacement or xylene substitute are not the same as true xylene — and that distinction matters when working with KBS coatings. Here is what sets them apart and what you should use instead.
❌ Do Not Use Xylene Replacement with KBS Coatings
Any product labeled xylene replacement or xylene substitute is a different raw material and should never be used with KBS coatings. It can interfere with flow, cure, and adhesion.
ℹ️ Why They Are Not Interchangeable
Xylene (xylol) is a specific aromatic hydrocarbon solvent with a well-defined evaporation rate and solvency level. KBS coatings are formulated around its chemical behavior.
Xylene replacement is formulated to reduce VOC emissions. It may look similar on a shelf, but it does not interact with coating chemistry the same way — and using it can compromise your results.
✅ Approved Thinners for KBS Coatings
1st Choice — KBS #1 Thinner: Our recommended thinner, formulated specifically for use with KBS coatings.
Alternative — True Xylene (Xylol): Acceptable where product directions specify it. Make sure the label says xylene or xylol — not "xylene replacement" or "xylene substitute."
Need an approved thinner for your KBS project?
KBS #1 Thinner is formulated to work correctly with our coatings — no guesswork required.
Shop KBS #1 Thinner Ask a Question
