Why Is It Important To Mix KBS Coatings Paints?
Proper mixing is one of the most overlooked steps in any coating project — and with KBS high-solids formulas, it's also one of the most critical. Because KBS paints contain a significantly higher concentration of pigment particles and protective solids than conventional paints, thorough mechanical mixing before every use is essential to achieving the color accuracy, adhesion, and rust protection KBS is known for.
Mixing at a Glance
Step 1: Tip can upside down (lid on) for 1–2 minutes before opening
Step 2: Attach Hurricane Paint Mixer to a 3/8" variable speed drill
Step 3: Mix at 500–1,500 RPM for a full 3–5 minutes, working the mixer to the bottom and sides
Step 4: Confirm uniform color and smooth consistency — re-mix every 20–30 minutes during long jobs
Why Mixing Matters
Why do KBS Coatings paints need to be mixed before use?
KBS paints are high-solids formulas, meaning they contain a much higher concentration of pigment particles and protective solids than conventional paints. Because these particles are denser than the carrier liquid, they can settle to the bottom of the can over time. Storing in a cool, dry place is always recommended.
An unmixed can has a thick layer of heavy paste at the bottom and thin, pigment-poor liquid on top. Applying paint in this condition produces the wrong color, weak protection, and poor adhesion. Thorough mixing before every use re-suspends all solids evenly so you get the full color, coverage, and protective performance KBS is known for.
What happens if I apply KBS paint without mixing it first?
Skipping the mixing step leads to several problems:
  • Wrong color — Pigment settles to the bottom; the top layer applies off-color and inconsistently.
  • Weak protection — Protective solids won't be present in the applied coat, leaving the surface vulnerable.
  • Poor adhesion — Thin, solids-poor paint won't bond properly, leading to possible early coating failure.
  • Uneven sheen & gloss — Inconsistent solids distribution causes flat spots, blotchy sheen, and mismatched gloss levels.
  • Wasted product — The thick sludge at the bottom is unusable if it hasn't been re-incorporated before application.
⚠ Don't Skip This Step
Mixing is not optional for high-solids coatings — it is a required part of the application process. No amount of additional coats will compensate for solids that were never properly distributed in the first place.
How to Mix Correctly
What is the correct way to mix KBS Coatings high-solids paint?
Follow these four steps every time:
  1. Keep the lid on tight and tip the can upside down for 1–2 minutes before opening. This loosens settled solids from the bottom before mechanical mixing begins.
  2. Attach the Hurricane Paint Mixer to a 3/8" variable speed drill (corded or cordless) and tighten securely in the chuck.
  3. Mix thoroughly. Start at a slow speed and gradually increase to medium speed (500–1,500 RPM), working the mixer to the bottom and sides of the can for a full 3–5 minutes.
  4. Check consistency by lifting the mixer. The paint should be uniform in color and smooth with no streaks or lumps before applying.
Shop Hurricane Paint Mixer
Can I just shake the can or stir it by hand instead of using a drill mixer?
No — shaking and hand-stirring are not effective for high-solids paints. The dense pigment particles and protective solids are too heavy to be adequately re-suspended by hand in any reasonable amount of time.
A mechanical drill mixer — specifically the Hurricane Paint Mixer — generates the rotational force needed to pull material up from the bottom of the can and blend it evenly throughout. Mechanical mixing also produces a more consistent finish compared to shaking.
How long do I need to mix KBS paint before applying it?
Mix for a full 3 to 5 minutes with the Hurricane Paint Mixer before beginning your project. The goal is a completely uniform color and smooth consistency with no visible streaks or settled material.
If the paint has been sitting for an extended period, it may take closer to 5 minutes to fully re-incorporate all solids.
The Hurricane Paint Mixer
What mixer does KBS Coatings recommend?
KBS recommends the Hurricane Paint Mixer — designed specifically for thick, high-solids coatings. Key features include:
  • Fits any standard 3/8" variable speed drill (corded or cordless), operated at 500–1,500 RPM
  • Blade design that pulls paint up from the bottom for complete mixing
  • Mixes in as little as 10 seconds once solids are loosened — no splashing
  • Works with pint, quart, gallon cans and 5-gallon pails
  • Heavy-duty metal shaft with durable plastic head; easy cleanup
  • Two sizes: 9-1/2" shaft for quart/gallon cans and 15" shaft for 5-gallon pails
Can the Hurricane Paint Mixer be used with products other than KBS paints?
Yes. The Hurricane Paint Mixer works with any high-viscosity material — paints, resins, epoxies, and other thick coatings — not just KBS products. It is an ideal tool for any project involving heavily pigmented or high-solids materials that require thorough mechanical mixing before use.
During & After Application
Do I need to keep mixing during a long painting job?
Yes. Because high-solids paints settle quickly, you should re-mix the paint every 20 to 30 minutes on any job that takes more than half an hour. A brief 30–60 second stir with the Hurricane Mixer is sufficient to keep the solids in suspension between coats.
Does temperature affect how I should mix KBS paint?
Yes. Cold paint is significantly harder to mix because low temperatures increase the viscosity of the carrier liquid, making it more difficult for solids to move freely.
For best results, let the can come to room temperature (65–85°F) before mixing. Do not apply KBS coatings below 50°F or above 90°F. Warming the can to room temperature before mixing also helps the paint flow and level more consistently during application.
💡 Cold Weather Tip
If your paint has been stored in a cold garage or unheated space, bring the can indoors and let it warm to room temperature for at least 1 hour before mixing. Cold paint is significantly thicker and harder to blend — warming it first makes a noticeable difference in mixing efficiency and final finish quality.
Does proper mixing affect the final finish quality?
Absolutely. Properly mixed paint produces a uniform sheen, consistent color, and even gloss level across the entire finished surface. Thin coats applied from a properly mixed can perform far better than thick coats from an unmixed can.
Mixing ensures the full protective solids content is present in every coat — which is what gives KBS coatings their long-term durability and rust-prevention performance.
Get Everything You Need for a Professional Finish
Mix right every time with the Hurricane Paint Mixer — designed for KBS high-solids coatings.
Shop Hurricane Paint Mixer Browse All KBS Products
